08-18-2019, 10:01 PM
Found this by accident
After drilling through the main 10/2 power cable while installing a set of Solid Steps in my '16 Windjammer 3001W I needed to access the void in the little end tables in order to pull a new cable through. After figuring out how to gain access and pulling the panels off I found this little hidden gem. There's a 12 volt breaker for the power stabilizers hidden inside the cabinet behind the switch. If it would have blown there's no way anyone would think to look there for a breaker!
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
08-18-2019, 10:06 PM
Are you surprised ? It's hard enough sometimes to find the water pump.
08-21-2019, 06:33 PM
Why do you think it's a breaker? From the looks of it, it may be a thermal overload switch and those usually reset themselves. I'm not seeing any way to reset that thing.
Ray
2020 Georgetown GT5 34H5
08-21-2019, 09:43 PM
Ray
I think it's a breaker because it's a breaker. Some are manually re settable, this one is not. And a breaker IS a thermal overload device!
ProPride 3P 1400
08-21-2019, 11:04 PM
Fuses are also.
This was the comment that threw me: "If it would have blown there's no way anyone would think to look there for a breaker!"
I was wondering if there was a button or lever on the other side of the wall.
Ray
08-22-2019, 02:59 PM
Fuses are also.
Ray
Outside, on the side of the trailer?
ProPride 3P 1400
08-22-2019, 10:27 PM
Sorry, I missed that part in your original post... [emoji4]
Ray
08-23-2019, 06:01 AM
You are right; its a thermal overload breaker.
It is also an "auto reset" type that will reset once the overload is removed.
When you run the stabs down and hold it, you can hear it pop on overload.
Once you let go of the switch, you can also hear it reset after a moment.
These can fail, but normally from corrosion at the terminal when located outside on the frame.
Herk
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
08-23-2019, 11:06 PM
Herk
No, it's not an auto reset breaker nor is it a manual reset breaker. It's an inline, 20 amp 12 volt breaker. Once blown it needs to be replaced.
https://imgur.com/a/ZoW1Nv7
ProPride 3P 1400
08-23-2019, 11:25 PM
If it isn't an auto reset, which is hard to tell without checking for numbers on the can because many look identical to the one time use, Can you replace it with some automatic reset ones while it's opened up?
https://www.amazon.com/Circuit-Break.../dp/B0027150H8
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
08-23-2019, 11:45 PM
Ray
I put the cabinet panels back on with velcro instead of staples so it's easy to get at if it does blow.
ProPride 3P 1400
08-23-2019, 11:54 PM
Easy to tell it's not auto reset even w/o looking at numbers because there's no button on it to reset! I put the cabinet panels back on with velcro so I don't have to tear it apart to get inside so there would be no problem replacing it if it does blow.
Great idea with the velcro, that was smart! The reason I mentioned it's hard to tell if their auto reset is because the auto reset ones I've used have no button at all. They just break the connection if the amp rating is exceeded to open the circuit and then just reset themselves when the overload is gone. I also have the manual ones and those have a little button on them. The automatic reset ones I linked to on Amazon have no button either. They do sometimes go bad, but more often when they're subject to corrosion.
Ray
2017 Rockwood 2109S
Ram 1500
US Navy Veteran
08-24-2019, 07:13 AM
Respectfully disagree.
It is a 6 amp auto-reset breaker; see install instructions attached.
08-24-2019, 11:45 AM
I guess the 20 amp printed on the breaker is a misprint. I call the manufacturer and let them know it should say 6 amp auto reset.
ProPride 3P 1400
08-25-2019, 07:06 AM
It is not unknown for the plant to use whatever is handy when installing stuff; according to Lippert that puppy should be 6 amps. The 20 amp fuse should be in your power distribution panel.
