Old 08-02-2015, 03:13 PM   #1
Front led dome lights and king jack antenna no power
I have a brand new 364ts. We stayed in it overnight for the first time. Woke up this morning and all three front overhead dome lights don't work and there is no power to the king jack air antenna. All four fixtures are in a row down the midline of the Rv from just in front of the bath to just before the front overhead bunk. Everything else works. I checked fuses in fuse box above rear bed and all fuses were good. Any ideas?
cousin eddie johnson is offline   Reply With Quote
Old 03-26-2016, 09:17 AM   #2
SternHappens's Avatar
We are set up in our 364TS and have been watching TV for 2 days, all of a sudden TV pictures freezes, change channel no signal, look up and no power on the King Jack antenna (had just been working fine) checked fuses over bed, nothing blown, everything else seems to be working, lights in kitchen, etc. Any idea where the fuse for the king jack is hiding?
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
SternHappens is offline   Reply With Quote
Old 03-26-2016, 11:54 AM   #3
The king jack power injector has a self resetting fuse, it should reset after cooling. If it does not might have had the power injector go bad.
Rich5117 is offline   Reply With Quote
Old 03-26-2016, 02:32 PM   #4
after flipping switch on and off a few times and tapping cases, I went to juggle the antenna, as soon as I push the button in and slightly moved it it came right on. So either that was coincidentally as the fuse reset or I have a loose connection in there somewhere. If it happens again, guess I open it up and take a look.
Old 03-26-2016, 03:34 PM   #5
Sternhappens I would still take off the cover and check the connections if your fuse got hot and tripped it may be a bad connection, at least it gives you some place to start
antenna, led, light, power
