Old 12-15-2011, 06:47 AM   #1
Front power stabilizers blowing 15amp fuse
When I retract my front stabilizers, it blows a 15amp fuse. It seems like the fuse blows when the stabilizers get fully retracted. Any ideas on what could be causing this?
Burch
MetalGator is offline   Reply With Quote
Old 12-15-2011, 07:35 AM   #2
Old car's Avatar
First time I brought mine up I guess I ran them to far and "bumped" the motor. Fuse blew right away. Replaced it and stop the stabilizers just short of hitting the frame and motor. Haven't had an issue since.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 12-15-2011, 10:48 AM   #3
Burch
Replace the fuse with an auto-reset circuit breaker - problem solved. This has been discussed previously and is a fairly common complaint. It is caused by the stabilizer motor(s) coming up against the stop but power still being applied causing an over-current situation.
...VTX-AL
VTX Al is offline   Reply With Quote
