Old 07-05-2016, 10:54 PM   #1
Front tongue LED
I own a 2014 Micro Lite 21FBRS. How do I replace the LED bulb in the light fixture on the exterior right side of the trailer's tongue? The plastic oval case is caulked, and the lens cover doesn't seem to be removable. Thanks for the help.
Hector517 is offline   Reply With Quote
Old 07-06-2016, 06:22 AM   #2
friendofacatahoula's Avatar
The lens cover should remove the same as the porch light.
It wouldn't have been caulked from the factory from any that I have seen. I use a flat blade screwdriver and pop either the top or bottom out and then it releases from there. I never remember which I pop out so try the top if it seems stubborn then go to the bottom. Mine is the 2109S, same trailer, different stickers.
2015 MiniLite 2109S
2016 Ram 3500 6.7
friendofacatahoula is offline   Reply With Quote
Old 07-06-2016, 07:29 AM   #3
Thanks, friend. I found other threads that say the same.
led
