Old 07-07-2019, 02:35 PM   #1
full power out of my solar panel
I have a 100w solar panel that makes 19V 5.2 amps. Is there a component that converts this to nominal 12V ~8 amps?
My current controller only gives me ~5 amps at ~ 12V - a flow through.
this kind of converter/ controller could give me almost 3 amps more!
does it exist?
Thank you
E Bergler
ebergler is offline   Reply With Quote
Old 07-07-2019, 02:41 PM   #2
does it exist?
Thank you
E Bergler
You need an MPPT type controller. You have a PWM controller. You wil lnever get 8A since the battery charges at between 13.6 and 14.5V. 7A is about what you will get if you aim your panel. You usually use 14.0V to determine the current. 100/14 = 7.14
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 07-07-2019, 04:57 PM   #3
Junior Old Fart
X2
2015 Jeep JK Rubicon
2019 Rockwood A122S
LTDunltd is offline   Reply With Quote
Old 07-07-2019, 05:31 PM   #4
Here's some interesting information (for the OP) found on the 'net that explains in more detail:
Q: How efficient is the MPPT solar charge controller over PWM (in percentage)?
A charging lead-acid battery limits the voltage of the charging source. A silicon solar panel produces a fixed current for a given brightness of sun. The mismatch between a fixed voltage and a fixed current is what an MPPT charge controller is designed to address.
Power is voltage times current. The current is constant, fixed by the brightness of the sun shining on the panels, so the maximum power is obtained at the maximum voltage. During the bulk charge a PWM controller simply connects the panels to the batteries. The power is therefore panel current x battery voltage.
However, the panel will still supply that fixed current at a higher voltage. The MPPT controller converts the voltage, giving the battery the voltage it expects while allowing the solar panel to provide current at a higher voltage. The power is the same (assuming the controller is 100% efficient, which it isn’t quite) but, as the battery voltage is lower, the current is higher and the battery charges more quickly.
To calculate the difference, calculate the loss using PWM as opposed to MPPT. This can be done by calculating the difference between peak panel voltage and battery charge voltage as a percentage.
Typical figures might be 18.5v for a “12v” panel, and anywhere between 13.6 and 14.4v for a “12v” lead-acid battery, depending on how full it is. So those figures might give:-
PWM loss, flat battery: 13.6v / 18.5v = 0.735 = 73.5%
PWM loss, mostly charged battery: 14.4v / 18.5v = 0.778 = 77.8%
Remember these are losses, and should be inverted to get gains.
MPPT gain, flat battery: 18.5v / 13.6v = 1.36 = 36%
MPPT gain, mostly charged battery: 18.5v / 14.4v = 1.28 = 28%
Note how the PWM controller becomes even less efficient as the battery reaches full charge.
The only time you will get max current from a PWM controller is as the above states, during the bulk phase when it's connected directly to the battery. It's also the time the voltage (measured at battery) will be at it's lowest.
Also, if you look at the data tag on the back of your panel there are two voltages and two amperage ratings. One is "Shorted" and the other "Working". To avoid disappointment, use the Working Output numbers.
And as babcock said, you need an MPPT controller. Better yet, add another panel and connect in series, feeding the higher voltage into the MPPT. I have a setup with two panels and you'd be surprised at how much charge current I read even when the sky is overcast. Not a ton but more than you'd expect, especially from a single panel.
When the sun's full I get enough to more than meet my daily "amp hour" needs.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 07-08-2019, 08:03 PM   #5
nodrawers's Avatar
Under 500w solar the difference is negligible
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
Days camped 2018 136
nodrawers is offline   Reply With Quote
Old 07-08-2019, 08:05 PM   #6
LOL....your theory on that is what?
Old 07-08-2019, 08:14 PM   #7
nodrawers's Avatar
Just a lot of research and talking too different system manufactures before installing my own very efficient system using an MTP CONTROLLER. 200W
Old 07-08-2019, 08:59 PM   #8
The conversion losses from the controller may be "negligible" (I woldn't guarantee that) but using an MPPT controller with multiple panels has another advantage. Transmission of DC power over a wire has much higher losses than AC. A piece of wire is an electrical resistor which will always absorb some power from the panels. Since power (watts) = I*I*R where R is resistance and I is current, doubling the current causes four times the power loss transmitting the power from the panels to the controller.
A 25' run from the panel to the controller has 50' of wire. #10 wire has around 0.05ohms resistance for this length. A 100W panel, at 7A, wold have 7*7*.05= 2.5W of power lost between the panel and the controller. 200W of panels in parallel would have 14*14*.05=9.8W of power lost. Wire the panels in series and you're back to the 2.5W lost. In both these cases, there's not a lot of power lost but if you're boondocking, you want to get every possible watt into the batteries.
Many other factors effect panel power output. Panels are rated at their maximum output , when facing directly into the sun when the sun is highest in the sky. This does not occur all day long which means that you always expect less output from the panel than its rated output.
Phil
pmsherman is offline   Reply With Quote
Old 07-09-2019, 01:19 AM   #9
My MPPT controller is 98% efficient. Let's say I had a 200W system like you do. Why would you be satisfied with 10A of output with a PWM when you could get closer to 14A with an MPPT?
power, solar, solar panel
