Old 10-18-2016, 08:58 PM   #11
If you want to stop the current draw on your trailer install a battery disconnect on the negative side of the battery and your problem will be solved. Remimber to turn it back on when you go camping or pick up at the storage lot. If you do not want to install the disconnect just remove the negative wire from the battery and reconnect when ready to roll.
sk734 is offline   Reply With Quote
Old 10-19-2016, 11:13 AM   #12
AKA: 'tiredTeacher
awellis3's Avatar
I needed to track the draws down because I dry camp. I noticed my Rockwood's battery bank was losing voltage faster than my old Sunline's did.
I disconnect the negative wire between trips, but I needed to find the source of my unusually quick voltage drop while I am camping.
It was the fridge defrost and wardrobe slide.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 10-19-2016, 11:46 AM   #13
I understand. Glad you were able to track it down.
Old 10-19-2016, 12:09 PM   #14
I always wire a battery kill switch to kill everything when I have it in storage. That includes the breakaway, levelers and so on. Trailer is a little more secure if someone trying to steal it they can't operate the jacks. I have to turn it on to hitch so then the breakaway and everything else comes on line. You could accomplish the same thing by pulling off a battery cable. Why mess with pulling fuses when you can just do this?
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 10-19-2016, 12:53 PM   #15
Please note my 5ver had a so called battery disconnect in the UDC but it did not kill everthing. I also put a kill switch at the battery to make sure no current is flowing to anything in the rig. Or as stated before disconnect the negative battery wire. See you down the road.
Old 10-20-2016, 01:40 AM   #16
Learning a lot as I go...
I found the culprit. It is the wardrobe slide. The switch that activates the control module (the in-and-out switch on the control panel) is powered through the fuse/circuit breaker panel and is disconnected by the battery disconnect switch inside the trailer.
However, this slide has a power cable that is fused (30A) off the battery directly to the control module. This circuit sends power to the slide motors 24/7 and is the braking mechanism that holds the slide in while traveling.
After disconnecting the heating element in my fridge and putting a switch in the power circuit to the slide motors, my phantom draws have been eliminated.
Interesting. I have a later model 2015/2016 2604WS and the cutoff switch is out front under the propane tanks. In mine the cutoff switch turned off about everything but the Zamp solar connector and I think the emergency breakaway trailer brakes.
I can believe that the front slide could draw a parasitic power since it uses an electronic controller module. I updated the wiring in mine to eliminate the auxiliary inline fuses under the left front corner (one 30A for each slide) and move them to a power panel in the front storage compartment. This was part of my install of a solar controller and current measurement shunt.
I also installed a switch in my Dometic to turn off the door seal heater and eliminate that draw.
With a 100A solar panel was able to easily survive a 4 day dry camp outing in July. Warm days made the side awning very nice and cooling at night made A/C not necessary. So solar was a fantastic solution there.
2015 Rockwood 2604WS (sold as 2016)
2014 Ford F-150 Ecoboost
stevejahr is offline   Reply With Quote
Old 10-20-2016, 11:52 AM   #17
MNtraveler's Avatar
There are a number of items that are powered by the battery even when the battery disconnect switch is off. It's unfortunate, but true. These can be small LED lights, radio/stereo back up memory power (to save GPS routes and station settings, for example), and hidden items like you found with the motor controller. Therefore, to preserve the battery when not in use, you will need to disconnect it at the ground terminal or install a disconnect switch right on the battery. If dual batteries, you will have to install it in such a way that both batteries are taken fully out of service.
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 32; RV to date: 35
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 10-20-2016, 03:32 PM   #18
AKA: 'tiredTeacher
awellis3's Avatar
Roger.
See Post #12
Wright and Penny
Richmond, Va.
battery
