Old 09-14-2015, 02:50 PM   #1
AKA: 'tiredTeacher
awellis3's Avatar
Full-time battery draw
My Rockwood 2604WS has a battery disconnect switch next to the converter. This disconnects everything that runs through the DC side of the fuse panel. However, there is something drawing current. When I disconnect a battery wire and touch it to the post, a very tiny spark and faintly audible sparking sound occurs.
Before I commence to troubleshooting this, has anyone else with a TT similar to mine found a "mystery user"?
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 09-14-2015, 05:57 PM   #2
Check your CO and propane alarms.
bruceatlam is offline   Reply With Quote
Old 09-14-2015, 06:10 PM   #3
AKA: 'tiredTeacher
awellis3's Avatar
Thanks. CO is battery operated. Propane detector has a monitor light that goes out when disconnect is engaged.
Wright and Penny
Richmond, Va.
Old 09-14-2015, 06:15 PM   #4
Rrickim63's Avatar
Can you use a multi meter to verify current draw?
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 09-15-2015, 09:32 AM   #5
AKA: 'tiredTeacher
awellis3's Avatar
LOL! Don't need a meter to see the spark. I plan to start at the buss bar and see if the draw is inside the trailer or outside. If outside, it'd have to be the tongue jack or the break-away switch. I hope it isn't inside.
I was hoping someone here with a Rockwood 2000 series had a similar problem and could steer me to it without my having to track this down, but he hasn't shown up yet.
Wright and Penny
Richmond, Va.
Old 10-16-2016, 10:54 PM   #6
cwilliamp's Avatar
I have a 2012 Wildwood and notice that although everything is turned off in the trailer the batteries would die during storage. I have inserted manual switches with all items I can not turn off, i.e. radio LCD and propane sensor. Today I extracted all the 15A fuses in power converter panel and measure with a amp-meter more than 150mA current draw.
I then extracted the 40A fuses associated with the "Reverse Polarity Protection" and noticed a spark. Using the amp-meter here I found that the connectors for the Reverse Polarity Protection is drawing current all the time.
I believe this is causing my batteries to die. I just don't know if this current draw is normal for this type of converter.
Charlie
2012 F150 & Wildwood T231RKXL
cwilliamp is offline   Reply With Quote
Old 10-16-2016, 11:11 PM   #7
Moderators' Assistant
bikendan's Avatar
Deleted
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 10-16-2016, 11:56 PM   #8
well, if it wasnt wired by a bunch of monkeys (so chances are high), the only draw with the battery disconnect disconnected, would be to the breakaway and 7pin 12v+. by chance was it hooked up to a vehicle when you tried this?
On mine they at least seem to have everything behind the disconnect, but its possible they have a radio memory wire or something wired direct (co/propane/smoke detectors would have been my other guesses)
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 10-17-2016, 12:16 AM   #9
cwilliamp's Avatar
The TT was not connected to a tow vehicle. Also, the TT does not have a "battery disconnect" switch.
Charlie
Old 10-17-2016, 11:15 AM   #10
AKA: 'tiredTeacher
awellis3's Avatar
Updating my own thread
I found the culprit. It is the wardrobe slide. The switch that activates the control module (the in-and-out switch on the control panel) is powered through the fuse/circuit breaker panel and is disconnected by the battery disconnect switch inside the trailer.
However, this slide has a power cable that is fused (30A) off the battery directly to the control module. This circuit sends power to the slide motors 24/7 and is the braking mechanism that holds the slide in while traveling.
After disconnecting the heating element in my fridge and putting a switch in the power circuit to the slide motors, my phantom draws have been eliminated.
Wright and Penny
Richmond, Va.
battery
