Old 11-23-2013, 10:20 AM   #1
Furnace Blowing Fuse
Hi everyone, New to the RV world. Having trouble getting my furnace to turn on. I noticed the 12vdc fuse was blown, tried another and blew. Im guessing short on wire somewhere or locked up blower motor. Just bought this fifth wheel and don't know much about it. What would be next step to check?Where is the blower motor? Would appreciate all the help.
Thank you
Amos2208 is offline   Reply With Quote
Old 11-23-2013, 11:00 AM   #2
Welcome to Forest River Forums!
The Fan is inside the furnace. It's all a self-contained unit. There are several documents for the furnace in the FRF library. Here's a link to the trouble-shooting guide to get you started. http://www.forestriverforums.com/for...do=file&id=119
I image the power to the furnace is connected thru a plug so the first thing to do is to unplug it at the furnace to see if the short is in the wires leading to the furnace or in the furnace itself. Good luck!
Old 11-23-2013, 11:05 AM   #3
Im gonna try it.
Thank You
Old 11-23-2013, 11:38 AM   #4
disconnected Ac out in furnace and still blows the fuse. How do u work on blower or squirrel cage?
Old 11-23-2013, 11:39 AM   #5
Wondering where the yellow/white wire coming off the fuse block goes to?
Old 11-23-2013, 11:43 AM   #6
Ford Idaho's Avatar
Would you care to explain this part?
Old 11-23-2013, 11:48 AM   #7
The furnace uses only 12v (and propane). Fuses in an RV are for 12v. Circuit breakers are for AC (120v).
Old 11-23-2013, 11:53 AM   #8
The fuse block has a 15 amp 12vdc fuse and the wire that is protected by the fuse goes behind the wall somewhere. Don't know if I answered your question.
Old 11-23-2013, 11:55 AM   #9
I would like to know how to get to blower motor?
Old 11-23-2013, 12:09 PM   #10
Ford Idaho, The Ac I was talking about is on the control module on the furnace. Now what the Ac does I don't know but it is AC Voltage.
sandpiper
