Old 04-03-2011, 11:25 AM   #1
Danimal's Avatar
Furnace keep blowing fuses
ok, i was in my new Rockwood 8281SS Fri. & Sat. and i figure i would try using the heater for the first time and it worked fine,
now i moved the camper back to its parking area and went to put the heater back on and now it keeps blowing fuses,
any ideas ???
2005 Dodge Ram
2011 Rockwood 8281SS
Danimal is offline   Reply With Quote
Old 04-03-2011, 01:52 PM   #2
KyDan's Avatar
Had a guy here last winter who's furnace was blowing fuses.
He found a mud daubers nest in the blower "squirrel cage".
You said yours worked and you moved it and now it doesn't
work so maybe that's not your problem but it's worth a look.
You should be able to open it up and get a long skinny screwdriver
in there and give the blower a nudge. It should turn effortlessly.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 04-04-2011, 06:22 AM   #3
Herk7769's Avatar
A careful inspection of the wiring may reveal the pinch that is blowing your fuse. Maybe a critter ate the insulation off a wire and after the move it is touching a metal frame.
HAM CALLSIGN - KC3FFW
Old 04-04-2011, 07:05 AM   #4
KyDan's Avatar
You can read a very similar problem, our suggestions
and what the owner found wrong here--
http://www.forestriverforums.com/for...use-10022.html
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-04-2011, 07:24 AM   #5
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Y'all are amazing.... how DO you get to the furnace? I wanted to look at mine one day...and could not for the life of me figure out HOW to get to it
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 04-07-2011, 06:30 PM   #6
Danimal's Avatar
i took to the dealer Monday night (still under warranty) no word on the problem yet
i will let you know what they find
2005 Dodge Ram
Old 04-08-2011, 04:44 PM   #7
Danimal's Avatar
called the dealer and they said it was the blower motor that is blowing the fuse
so they orderd a new motor, should be in next week
thanks for the replies
2005 Dodge Ram
