Old 07-09-2011, 11:59 AM   #1
Boyd's Avatar
Fuse between battery and inverter
I'm installing a 600 watt inverter and wondered if this type of fuse will be adaquate: 6, 8 or 10 GAUGE AGU 80 AMP FUSE Inverter to battery leads are 6 gauge.
I found this fuse holder on ebay $7.95 What-cha think?
http://compare.ebay.com/like/2707017...=sbar&_lwgsi=y
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 07-09-2011, 12:20 PM   #2
More than adequate, if its a short run actually a bit over the top for a 600W inverter, could probably run a 1000-1200 with 6g under 10'
Fuze size is good as well 600W/12volts is 50 amps draw
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
battery
