Old 04-22-2012, 02:44 PM   #1
Fuse box problem?
I just bought a 2005 Wildwood 26'. Everything seems to works fine. When I am plugged into shore power, I hear a slight humming sound coming from the panel beneath the fuse box in the bathroom. I am wondering if this is a fan to cool it or if there may be a problem. Pictures of the fuse box on top and the panel (which I can't get into.) on bottom.
ID:	12534   Click image for larger version
witchcraft is offline   Reply With Quote
Old 04-22-2012, 02:49 PM   #2
Probably the cooling fan on the converter. If you turn everything off, the fan will shut off as soon as the converter reaches its proper temperature.
Old 04-22-2012, 03:02 PM   #3
Just to be sure, you should somehow check to see if you have airflow. Maybe you can hold a small ribbon of tissue in front and check for air movement. Depending on the humming noise, it could be a stuck fan in the converter.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
