Fuse Box Wiring
Furnace quit working (nothing comes on as in no power) so I looked at fuse box first. Fuse also runs water pump. Water pump no power either.
Swapped out 15 amp fuse. Still nothing. I have been parked for a couple years (full-timer) in one spot on grass. I have had problems with Texas Crazy ants getting in electrical outlets and blowing GFI. WF-8900 Series converter is located under stove. Can I pull it out from the front to check where the wires are connected to the fuse to see if that is where my problem is? Anything else I can check?
