Old 01-27-2014, 04:31 PM   #1
simplyrwc's Avatar
Fuse in battery cable
On my 2014 Wildwood 32bhds there is a battery cable that goes from the battery to the trailer. There is a fuse on this cable. I would assume that when you pull the fuse the power to the trailer from the battery would be cut off but it isn't. I still had some power? Thoughts?
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 01-27-2014, 05:45 PM   #2
iceblaze580's Avatar
It should cut of the power by pulling the fuse the battery is still supplying power some how are there two cables on one battery terminal
iceblaze580 is offline   Reply With Quote
Old 01-27-2014, 06:01 PM   #3
Cyber Phrenologist
Radio's Avatar
On my fiver there is the main battery cable. There is an additional cable, somewhat smaller, that has a 30 amp inline fuse holder. On my trailer this cable goes to the front jacks.
Likely your cable goes to slide out motors, jacks, or other high current draw system. Pull the fuse again and try moving the slide room, jacks or whatever else draws a lot of power.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 01-27-2014, 07:42 PM   #4
RPAspey's Avatar
Did you remove shore power?
2000 Cherokee, LEDs, solar, inverter, etc. '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 01-27-2014, 07:51 PM   #5
2007 WildCat 32QBBS
05CrewDually's Avatar
Were you still plugged into your tow vehicle? Your tow vehicle charges the trailer battery while driving and will power up the trailer even without a battery installed. Just a warning, don't power up anything with a large draw or it will pop the TV's fuse.
05CrewDually is offline   Reply With Quote
Old 01-27-2014, 08:11 PM   #6
simplyrwc's Avatar
No shore power
Not hooked to tow vehicle
Never really traced the two cables. Just assumed the fuse would cut all power. It does cut power to the tongue jack I know that for sure as I've tested it. I will ok have to experiment with it next time I'm out.
2013 Days Camped 14
Old 01-27-2014, 08:47 PM   #7
Some trailers have multiple lines on the battery sounds like you pulled the fuse to the tounge jack and other wires are still attached to the battery if your looking to disconnect power from the battery I would get a disconnect switch
battery, fuse
