Old 05-23-2012, 11:48 AM   #1
fuse on pump blows
The fuse for our pump blows when we open or close the slide. Any idea what might be causing this?
biskupski is offline   Reply With Quote
Old 05-23-2012, 12:11 PM   #2
TURBS's Avatar
Im guessing the wires are rubbing on the slide rails .
Old 05-23-2012, 12:37 PM   #3
Bad pump motor or a loose/coroded connection. Check and clean connections. If that does not work pull the motor out and have it tested.
