Old 06-23-2016, 08:43 PM   #1
fuses
the co detector has to be replaced due to end of life. Now the fridge is on auto but is using gas and not electric. Also, Now the stereo has no power. There are no fuses out or breaker tripped.
ma and pa burch is offline   Reply With Quote
Old 06-23-2016, 08:46 PM   #2
SeaDog's Avatar
Are you on shore power? If so then there is a problem with your 110V power source you might take a tester and check the converter to see if you are actually getting power.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-23-2016, 08:59 PM   #3
Left Coast
Converter also has a fuse...
Old 06-23-2016, 09:02 PM   #4
thanks
New to rv, where is this converter?
Old 06-23-2016, 09:24 PM   #5
Mr. Dan's Avatar
You might tell us what kind of RV you have - make & model. Without knowing, we'll have to guess. So... guessing, I'll say if you found the fuses and breakers, you found the converter. There are 2 30 or 40 amp (guessing here) fuses in that panel that are usually NOT aligned with the others. IF you removed/reinstalled your battery AND you hooked it up backwards, you blew both of those fuses.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-23-2016, 09:40 PM   #6
Left Coast
Where the land line connection outside, the converter is usually in that area inside....might be a false back in a cupboard hiding it .....false backs are screws into place, easy to idenify
Sent from my XT1585 using Tapatalk
fuse
