Old 09-08-2013, 06:40 PM   #11
Originally Posted by IHDRIDER00 View Post
There is an on-off switch behind the gen. fuel pump. It seems to turn off the 120V. Does anyone know how this is supposed to be used? Can I turn this off, start the gen., plug in then turn the switch to on? Thanks
That should be the breaker, yes that will work fine.
Acableguy06 is offline   Reply With Quote
Old 09-09-2013, 09:58 AM   #12
IHDRIDER00's Avatar
Thanks Acableguy06, That's how I used it. It ran fine for about 4hrs. Then it started surging. I turned off all loads. Turned off the gen. Now I have no 12v to the fuel pump. Oil is fine. Everything I've read so far points to the board. Any idea? I'd like to be sure before I replace it. Thanks
IHDRIDER00 is offline   Reply With Quote
Old 09-12-2013, 06:56 PM   #13
I think you should have a 10 amp fuse by the on/off start switch. Check that.
