Old 07-10-2016, 08:26 PM   #11
Who Dares, Wins
doc73's Avatar
When I said heater I meant WH, my bad.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 07-10-2016, 08:37 PM   #12
It was off
mjh203 is offline   Reply With Quote
Old 07-10-2016, 08:44 PM   #13
Flybob's Avatar
When you say 30A adapter are you talking about this
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-10-2016, 08:58 PM   #14
this one...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 07-10-2016, 09:07 PM   #15
Flybob's Avatar
same thing.
Try to get hold of a meter that can measure the current on that circuit to determine if it is actually a high load or just a bad generator. This is always a handy item to have in an RV, It can save a lot of headaches and guess work.
https://www.amazon.com/P3-P4400-Elec...illawatt+meter
TST Tire Monitors
2 65W solar panels
Old 07-11-2016, 01:53 PM   #16
Originally Posted by Flybob View Post
same thing.
x2, same thing.
Turn all your 120v circuits off, hook up the genny, and turn on circuits one at a time. This should help identify the offending circuit.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 07-11-2016, 06:26 PM   #17
Too Tall's Avatar
I think it's got something to do with the IQ sensing a ground issue. Contact Generac more info? In the mean time get one of these or equivalent. You'll never regret it. It measure AC/DC amps, volts, temp etc..
https://youtu.be/ZWshTRjsqHY
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 07-14-2016, 09:12 AM   #18
Will do. Thanks!
Old 07-14-2016, 09:14 AM   #19
Thanks!
Old 07-14-2016, 09:55 AM   #20
Too Tall's Avatar
That's a strange problem but it's not the IQ. The IQ is a very nice little unit, don't give up on it. I've heard of grounding issues with other generator/ TT combinations. Someone more knowledgeable than I may be able to shed some light. With an ammeter, you can definitely rule out issues.
The iQ should run just about everything but the AC and Microwave at sea level. With a few simple mods, you make crank the 13.5 BTU AC. Some folks are running them with 2000 watt units. A hard start capacitor and time delay on the fan will knock off about 10 amps of the starting surge. But that's after you figure out your immediate issue.
USMC 68 -70
generator, inverter
