Old 07-10-2016, 06:16 PM   #1
Generac iQ2000 inverter/generator and R-Pod 178
Hello,
I did a bunch of research on portable generators and decided on a new Generac iQ2000 Inverter. It is quieter than a Honda EU2000 and had really good reviews. So, I went on a trip and tried to use this for the first time on my 2015 R-Pod 178. The generator fired right up and gave me the green ready light. As soon as I plug in the camper, it switches to red and will not power anything in the R-Pod. The only things turned on in the camper are the clock on the microwave which instantly comes on with electric and the clock on the Radio/DVD player. I cant turn these off. Everything else was off and/or unplugged.
I tested my dads old 1978 camper with the iQ2000 and it worked just fine. Not enough to power the AC, but lights and outlets worked fine.
What am I doing wrong? Shouldn't this unit be adequate for this small little camper? Thoughts or suggestions?
I went ahead and returned the iQ2000 today. Suggestions from any other R-Pod owners for a good size inverter/generator unit?
mjh203 is offline   Reply With Quote
Old 07-10-2016, 06:18 PM   #2
Who Dares, Wins
doc73's Avatar
2000 should be more than enough for most things minus the AC. Is there an electric element in the heater that was on? I run my whole trailer on one eu2000 with a second if I need the AC.
Sent from my SM-G930V using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon-EOW 11/22/2017
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-10-2016, 06:21 PM   #3
The power source to the heater, ac, and fan is all done through the thermostat. It was all turned off.
Old 07-10-2016, 06:38 PM   #4
Travelling Texas
DavidBo's Avatar
The only other power hog is the water heater, I assume that's off. Do you have any problems if you hook it up to regular house current?
DavidBo is online now   Reply With Quote
Old 07-10-2016, 06:39 PM   #5
Flybob's Avatar
There were a few other things most likely on, but still not enough to overload a 2000 generator. The converter, and CO/Propane detector were on. Are you sure you did not have WH on electric?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-10-2016, 06:58 PM   #6
Thanks for responding. You are correct that the CO Detector was also probably on. I am sure the WH was off as I am having problems with it too. I can not get it to light or turn on with electric or propane. No idea what is going on with it. I made a separate post in the plumbing forum to try to get help on this issue. It goes through three cycles of clicks like it is trying to light, but wont work.
Old 07-10-2016, 06:59 PM   #7
everything works fine when plugged into the house (except the water heater which is currently not working at all). I cant get it to light on propane or work on electric.
Old 07-10-2016, 07:28 PM   #8
NMWildcat's Avatar
My buddy went through 3 generacs before he gave up. Now he is on his second champion. My 2 Honda eu2000i cost a little more but they are now 10 years old and still going strong. That fact really upsets him when I rub it in..... 😂
Does sound like something in your rig is drawing more power than it should.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-10-2016, 07:32 PM   #9
Travelling Texas
DavidBo's Avatar
Normally I'd blame a bad genset, but it worked fine on your older trailer so hmmmm...
Are you running any kind of voltage protection on the R-pod?
Old 07-10-2016, 07:34 PM   #10
Not that I am aware of... I simply plugged the iq2000 into the camper with a 30amp adapter on the end of the provided RV cord.
generator, inverter
