this is probably already covered if you bought a ready made adapter. the issue is bonding the neutral and the ground leads. most generators do not bound these but the rv wants it. check the adapter to see if it does this. or check to see if the generator does or has an option to do this. if so, good to go
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
