Old 05-04-2012, 06:36 PM   #1
Generator
What size generator do I need to power my 2013 Forest River Salem 30QBSS?
casinojen is offline   Reply With Quote
Old 05-04-2012, 06:51 PM   #2
steeleshark2's Avatar
The boliy 3600 would do you just fine to run everything.
steeleshark2 is offline   Reply With Quote
Old 05-04-2012, 06:53 PM   #3
Mountainmanbob's Avatar
if
if
we go to the search engine here on page
and look around a little
there are many good long threads regarding
what generators it takes to run
1 - AC
or 1 - AC and other elect appliances
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 05-04-2012, 06:57 PM   #4
Afew questions. Do you plan to power your AC with it? What other appliances do you want to run with it. Is quietness important to you? Answer these and you will get some good responses.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 05-04-2012, 06:58 PM   #5
TURBS's Avatar
this is handy when looking at what you need for generator amps http://www.forestriverforums.com/for...aws-17300.html
Old 05-04-2012, 07:00 PM   #6
a 13.5BTU air conditioner and the lights. Fridge and water heater will run on the propane tanks. Quietness is semi-important. Want to be able to camp with family at a cabin that will blow if we plug into it.
Old 05-04-2012, 07:00 PM   #7
do you know where it is made ?
looks nice steeleshark
Mountainman
SMALLEST SIZE - BIGGEST POWER
ONLY $1,199.00
This unit is a manual, or pull start generator. Weighing in at only 68 lbs it has the lowest weight in its class. The compact size makes it the perfect fit for campers, motorhomes, or toy haulers.
The 3600 SI/E is the newest addition to the Boliy family. This model comes with an electric start which allows you to power up the unit with just the touch of a button. Weighing in at only 75 lbs this unit is still lightweight and is the exact same size as the pull start model.
The Boliy 3600SI+ is the perfect generator for everyone! This unit is the smallest in its class which makes storage easy. Plus it is lightweight which makes transportation easy. Finally, it is packed with power! This unit is even powerful enough to run a 15,000 btuh A/C unit.
Boliy generators contain DSP inverter technology which allows the voltage to constantly adjust in order to maintain 120V. These digital generators are fully equipped with unique on-demand smart-throttle which automatically regulates the engine speed according to the load. This results in 40% less fuel consumption when compared to traditional generators. This of course extends running time!
The Boliy generator engine also features a special cylinder coating for strength and efficiency. They also contain a newly designed two-tiered noise dampening system. The result is that the Boliy dB’s emitted are 4- 8 times quieter than conventional generators. This meets the newest noise level standards enforced in many states, municipalities, and parks.
See how Boliy sizes up against the competition
Boliy Pro 3600Si & SI/EHonda EU300isYamaha EF3000iSEMax OutPut (Watts)330030003000Rated OutPut (Watts)300028002800Dry Weight (lbs.)68 (SI) or 75 (SI/E)134152Noise @ 1,000 Watts (dB)536058Gallons per Hour 1/4 load0.170.220.185Inverter TechonlogyDigital Signal ProcessingCyclo ConverterPulse Width ModulationDimensions (inches)23 x 16.5 x 18.525.8 x 18.9 x 22.426.7 x 17.5 x 21.9Retail (MSRP)$1,199.00$1,999.95$2,299.00
2010 Improvements
  • 100% Proformance test approved
  • New High Flow Fuel System
  • New Fuel Tank Design
  • New Improved Cooling System
  • New Cold Air Intake System
  • Stricter quality control procedures
Features
  • Lowest Weight - 68lbs (3600 SI) & 75 lbs (3600 SI/E)
  • Enviornmentally Friendly
  • DSP Inverter Technology
  • On Demand Smart Throttle
  • 25 Amp Circuit with 30 Amp RV Plug Standard
  • Low decibel level
  • 53 to 58 dB at 1/4 load
Specifications & Dimensions
Overall Length23"Overall Width16.5"Overall Heigth18.5"Dry Weight (3600 SI)68 lbs.Dry Weight (3600 SI/E)75 lbs.Gross Weight78 lbs.Fuel Tank Capacity1.9 US GalNoise Level (1/4 load at 7m)53-58 dBGenerator
Rated Output 3000 WattsMax Output3300 WattsFuel Tank Output13,500 WattsRun TIme (1/2 rated load)7.5 hoursRun Time At Rated Load4 hoursPower conversion Rate85-92%Rated Voltage (V)120V North AmericaRated Frequency60 50 HzRated Current25A at Full PowerDC Output (12V/8A)YESWarranty
Consumer use: Includes 2 year Parts & labor coverage plus 2 year emissions warranty. See the Boliy website for more information Boliy Pro 3600Si
ONLY $1,099.00
Boliy Pro 3600Si/E
ONLY $1,199.00
Old 05-04-2012, 07:11 PM   #8
Personally I would look at something around 3000 watts. I had a Yamaha ef2400 that I had mixed results with starting the AC and that was with a soft start capacitor on my AC. I believe it was due to my altitude of 6500 ft. I just replaced it with a Honda eu3000is generator. I am very happy with it. Starts the AC without a hitch with some room to spare. It is extremely quiet and seems to be very fuel efficient. There are numerous generators out there. Honda, Yamaha and Boliy are among the quietest. Honda and Yamaha are spendy but well tested and reliable. I almost bought a Boliy but was scared away at the last minute by a few reviews I read. There are some good reviews on it as well but in the end I went with the Honda. It is hard to find a bad review on them or the Yamaha. I chose the Honda over a comparable Yamaha for a couple reasons. About 20lbs lighter, slightly better DB rating of 49DB verses 53DB rating at 1/4 load, 3 year warranty and about $250 less. You can't go wrong with either one though.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Old 05-04-2012, 07:15 PM   #9
What if I didn't run the air?
Old 05-04-2012, 07:16 PM   #10
You could get by with 2000 watts and still run microwave, etc. I would recommend listening to a few different ones before deciding. You will get sick of listening to the louder ones in a hurry.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Old 05-04-2012, 07:23 PM   #11
TURBS's Avatar
look at post 5 and click on the link .
right down the things you would use then add up your watts .
normal gennies have 2 sets of 15 amp plug ins with a 30amp twist lock plug .
Old 05-04-2012, 07:33 PM   #12
Actually both the Honda and Yamaha 2000 watt generators have dual 20 amp plugs and no twist lock. If it has a twist lock you will need to get an adapter to go to your TT power cord. The Boliy has the standard 30amp RV connection.
The Honda 2000 Companion does have the twist lock.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Old 05-04-2012, 07:35 PM   #13
TURBS's Avatar
thank you !
Old 05-04-2012, 07:52 PM   #14
Thanks for all the info everyone, but don't think I'm ready to spend $2500 for a generator....WOW. Happy camping!!
Old 05-04-2012, 08:10 PM   #15
There are much cheaper options but usually at the expense of quietness. Look at the Champions. Some good reviews on them.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Old 05-04-2012, 09:02 PM   #16
Oakman's Avatar
Did you read post #2 and #7? Boily 3600 generator for $1200 and it has a 30 amp plug. It will take care of your needs.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-04-2012, 10:20 PM   #17
bikendan's Avatar
it would help if you gave us an idea of how much you're willing to spend.
the rule is that you have two choices in generators: price or quietness.
you can't have both.
if you aren't in a campground, the Champion 3500 is the best bang for the buck, around $300US. but it's noisy compared to inverter generators.
if you want quiet, it's going to cost you.
Old 05-04-2012, 10:26 PM   #18
ryand's Avatar
A few weeks ago I went to Kansas Speedway and had a chance to hear every type of generator....I came to camp with our Yamaha 2400...that will run the A/C by the way....But had a chance to talk and listen to both Champion units (inverter type and Conventinal) and must say I was impressed. The 3000 unit was not really that bad. However I must say it was overshadowed by the guy with 10,000 generator that was so....so...so loud we had to park trucks in front of it to just be able to hear each other yelling.
I like my Yamaha....it does what we need it to do. I can handle turning the air off for coffee and microwave use and keep the $1,000 I saved in my pocket. Plus I can move it on my own and it fits in my truck with the cover on.
2019 SOB Bunkhouse (Former Coachman FR Owner)
2015 Ram Bighorn 2500 6.4L
https://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 05-05-2012, 04:49 AM   #19
the day will probably come
when you will wish that you would have
bought one that would also run the AC
now is the time to buy the right one
Mountainman
Old 05-05-2012, 04:09 PM   #20
Mark S's Avatar
I felt the same way about spending $2-3,000 on an occasional use generator. I just purchased the Dometic 3000 for about $1,000. Runs the 13,500 air with everything but the microwave with no problem and is relatively quiet. Haven't used it camping yet but my test runs have been good.
Mark S is offline   Reply With Quote
