Old 11-15-2014, 12:40 PM   #1
rracer5's Avatar
Generator
Posing this question(s) to all who have "tackled" this issue;
Since we are now full timers, I'm thinking of adding generator capabilities for those long trips where we may end up dry camping (some federal or state parks) for a day or two or overnight stops (in truck stops or Walmarts).
1 - Have a RV specific generator installed in the 50 amp 5er (ie; Onan GenSet). Cost of unit + install. Pros vs cons of onboard Generator. ( shouda had one installed when I ordered the 5er)
2- One portable generator (ie; 3000/3100 watt Honda or Powerhouse) and where do you store it and has anyone run it while in the front generator bay with hatch doors open of course. (At around 150 lbs, it would be difficult to get it out of the bay to use).
3 - One or two portables (ie; 2000/2100 watt Honda or Powerhouse) at only around 40 lbs each, mush easier to remove from storage bay to run outside.
Any suggestions will be helpful (trying to convince DW, .....and myself, what might be the best option for us).
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-15-2014, 03:45 PM   #2
HONDAMAN174's Avatar
Generator
I like the idea of two 2000's because they are lighter and produce more than one 3000. Now I have two Honda's, one I purchased new and one from CL. But I rarely have a need for two. Here is another cost effective unit others have said is a good value and can be paralled:
Champion Power Equipment 73536i 2,000 Watt 4-Stroke Gas Powered Portable Inverter Generator (CARB Compliant) https://www.amazon.com/dp/B0041K09D8..._cH8zub0PZDTVC
You can buy the pair for the same price as one Honda- but ask around on here for reliability.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 11-15-2014, 10:29 PM   #3
jb3-7-77's Avatar
I really like the idea of two 2000's, myself. Lots of pros, including being much more versatile for storage and moving purposes. Plus, if one happens to go down, you already have a spare! To the best of my knowledge, the only time you'll need both of them is for the air conditioner; at least in my experience the 2000 powered everything without much of a hitch. (The "much" refers to the generator sometimes bogging down when the microwave is initially turned on)
As far as which generator, I have a powerhouse as that is what my dealer stocked and have been able to do some comparative testing with Honda and Yamaha units. I would highly recommend the Yamaha or Honda over the powerhouse. "But what about the remote start?" First of all, it's much heavier. Not a problem for a strapping young lad like myself **brushes imaginary dust off shoulder** but my wife wasn't terribly enthusiastic about moving it around. And she is tough! Anyway-remote start. Yeah, it wasn't really that great, as most of the time it would start after a few minutes of cranking (and you would need to open the window to listen to it try to start. After a couple seconds it resets itself and you need to push the start button again until it doesn't start again. Repeat this process for ten minutes) but as soon as the camper switched to shore power the genny would die if left in Eco-mode. I would have to go out and pull-start the thing with Eco-mode turned off, let it warm up for a few, and then I could switch it over. I can only think of one instance where the remote start actually worked, but even that took ten minutes. I just wanted to see if it would actually work. Also, the powerhouse is noticeably louder than the Honda or Yamaha. If you are still stuck on getting one, I'll make you a great deal on a slightly used unit! 😊
jb3-7-77 is offline   Reply With Quote
Old 11-15-2014, 11:08 PM   #4
SKnight's Avatar
It's really hard to beat Honda reliability. I recently got the twin EU2000i generators and in testing love them, I'll really test them next week but on paper they're the best of both worlds.
Light. 49 pounds each I can carry both easily (I'm a big guy, but still they're manageable.) to the tree line, or back to store them for safekeeping.
Powerful. 2000 watts surge, 1600 continuous. Parallel gives 3200 continuous or 26.6 amps. Plenty to run the AC and anything else I need. Or if the AC isn't needed I can run the rig off one generator. Several have tested them in comparison with other brands and the Hondas come out on top. Plus they sip fuel, and if I only need one I'm in great shape for days with an extended run tank.
Quiet. You can stand next to one or both and hold a normal conversation.
It's a lot of flexibility in a easily manageable package.
Old 11-16-2014, 01:22 AM   #5
The Honda/Yamaha debate will continue, but can't deny that 2 of those little 2000w inverter genny's isn't a really nice setup. Efficient, quiet, reliable, lightweight... 2000w is typically enough for the day to day, but you can always run in parallel to run your A/C. For the day to day it's always nice having a backup genset on hand.
I'm a full time boondocker, and aside from the initial expense, in the 3 years I've been running my 2 Yamaha's I've yet to find a downside.
Well... I take that back... Initially, one thing I really hated about them was the oil point access port. Pain in the rear to get to, the cap is another pain to get open, there's no real way to check the oil level, and there is no way to fill or change the oil without making a mess.
A quick trip to ebay solved that though. You can find screw in oil filler tubes and a knurled knob oil cap with a built in dipstick. NOW I have no complaints. :-)
rana is offline   Reply With Quote
Old 11-16-2014, 04:33 AM   #6
mud yapster's Avatar
Don't forget a lot of state and federal parks have noise restrictions for generators so picking a quiet one will keep you out of trouble with the warden.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-16-2014, 06:09 AM   #7
B and B's Avatar
Was looking at twin 2000's here but they are not legal or sold in Canada. Now looking at the EU3000IS Honda. It is 23.3 amps vs 26 amps for twin 2000I Honda. It has a large fuel tank and one box. I can use a ramp to put it the back of the truck and use it there when needed. The twin 2000's needs and extended run tank to last the night and the Champion which I was looking at doesn't have extended run option running out mid way through the night.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-16-2014, 07:20 AM   #8
I don't know if that is always true. Mind you I have never run one all night, but I run my furnace off one before so I know that a furnace will run fine in eco-mode.. and I know I can get around 10 hours of run time with a single fill in eco-mode. From that, I would hazard to guess one should be able to run typical loads throughout the night on a single tanks.
Of course.. if you are talking about running your A/C on twins all night.. that a different story. Probably would only get 4-5 hours then.
Extended run tanks aren't too hard to throw together. Including the tank and hardware I put together a dual extended run tank for about $70.
That's with all the bells and whistles.. in line fuel filter, bulb pump, shut off valves, marine grade locking fuel connectors.
Old 11-16-2014, 08:37 AM   #9
RPAspey's Avatar
You're right. I used my Yam for the HS band show to run 2400 watts of smoke machines. The other bend roadies couldn't believe how quiet and powerful it is. In fact one of them bought one a week or so ago.
You are right about the oil change mess...I took the panels off to get better access to clean the mess and clean the air filter. But, on the bright side, I only have to do it once a year.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 11-16-2014, 01:34 PM   #10
rracer5's Avatar
Thanks guys.......keep the comments coming. Lots of stories and scenarios will help alot.
2014 Sanibel 3250
generator
