02-09-2016, 05:05 PM
Generator and UPS Question
Has anyone used a non invertertor generator with a APC UPS that has voltage regulation built in? Read online a lot of people are using this set up in their home, APC1300 with a generator with great success saving thousands.
2015 Sandpiper 30IOK
2019 GMC 2500HD 6.6 Duramax
02-09-2016, 05:08 PM
Who Dares, Wins
Is the plan to use the generator at home? The reason I ask is you will have some every sad neighbors at the campground if that is what it is for.
2015 Chevy HD D-Max
2022 Impression 315MB
02-09-2016, 05:33 PM
Saving money as compared to what?
And depending on the quality of the generator output, the UPS can be pretty unhappy...
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
02-09-2016, 05:54 PM
Very inefficient system. Also even a 1000W UPS is very heavy. Not to mention the generator noise. Non-inverter generator will cause UPS alarm to activate so unless you have one where you can disable alarm you won't sleep.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-09-2016, 11:11 PM
Are you talking about an UPS with a battery backup for computers and low wattage needs? I don't see how that's going to save money, with or without a generator. Running a generator in place of municipal power is not competitive even at the low current fuel prices.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
02-10-2016, 12:30 AM
No I have a generator and pannel setup at home.
Cheaper as in a $499 generator and a $250 UPS compared to. $3500 inverter generator, cdn.
This is not to use instead of shore power, to use when there is no shore power.
Not worried about neighbours where this is used.
They are being run in homes with non inverter generators and not alarming. But only know of two.
02-10-2016, 11:39 AM
If noise isn't an issue, why not just run off of the generator, without an invertor and get the full wattage?
USMC 68 -70
02-10-2016, 12:56 PM
Are you asking if running the generator output through a UPS changes the sine wave of the voltage? If so, then I see where you are coming from. I haven't personally used this, but it might work. Personally, it would seem that the best practice would be to run the genny output through a UPS without batteries would be the best way to convert the output to pure sine wave, so that appliances in the RV would have "conditioned power", as opposed to the "dirty power" that comes out of a standard generator. That would bea good thing, but not sure if the circuitry in a UPS does this.
02-10-2016, 01:03 PM
How big of a ups are you looking at using? I just bought a 2800W peak 2600W running inverter generator for $799 cdn.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
02-10-2016, 06:00 PM
Too Tall: Regular Generators are know to have poor voltage regulation and put out what is commonly referred to as "dirty power". Generators have been known to blow up electronics such as smart phones, laptops, newer electronics and cause issues with the converter in the trailer. Inverter Generators with manage the voltage and power are more expensive because of this and what I am trying to do is bypass the purchase of an expensive generator by inserting a voltage regulation and serge protector into the line for an extra $200 instead of an extra $2500 in cost.
Moodman: Some of the terms you use I have heard of reading up on the topic but not positive what they all mean. Basically I am looking to start a regular 4500 generator, run the line to a APC 1300 then plug the trailer into the APC. The APC will handle a solid 20amp load, although I have multiple electronics we can capably manage our use on a 20amp service. I just want to cut out the chance of blowing up my gear.
Happy vibe: looking at a APC 1300 UPS. Not looking for the battery back up part but the voltage and serge protection. The generator I am looking at is the Honda EU3000I. What kind of generator and where did you buy for 799.
02-10-2016, 06:18 PM
Denver, CO
Your idea should work fine depending on the specs of the APC UPS. If some folks are using this approach off the grid, they can be pretty clever. On the other hand, voltage regulation and surge protection, per se, has nothing to do with the square wave problem that conventional generators have and that causes most of the problem with electronics. If the dirty power is dirty because of fluxuating voltage that is one thing, but if it is because of a square wave AC shape instead of sine wave, then the issue may not be solved.
2017 Fuse 23T
02-10-2016, 07:48 PM
Yes, I see your concern. I ran my laptop and other stuff off a standard generator for years without problem. We did usually use a UPS for desktops just to prevent from losing data if the genset shut down. Laptops and cellphones have their own built in UPS since all you are doing with the AC power is charging a battery thru a regulated power supply.
USMC 68 -70
02-11-2016, 12:29 AM
I bought a Boley 3600ESI inverter generator for $999.00 new. use on my TT works great puts out 52dbi. Check on line.
02-11-2016, 02:09 AM
2012 Solera
I believe my home UPSs connect the incoming power to the output unless the incoming is interrupted. Unless I'm mistaken, only on incoming power interruption does the UPS supply power from its inverter.
To do what you want - to condition the power by using the incoming to charge a battery, then run an inverter from the battery and use the inverter output to have "clean" power - I believe you will either have to hack the UPS or just get a bartery charger, battery and an inverter (build the device you want from components).
JLeising
2012 Solera "S"
Calif SF Bay Area
02-11-2016, 10:29 AM
An AC utility demonstrates a typical UPS output. First (leftmost) waveform is a UPS output when AC input connects directly to UPS output. Waveforms on right are a UPS output when in battery backup mode. View Tech Tip 3
UPS manufacturers quietly recommend not using a UPS on motorized appliances. That 'dirty' power can be problematic to motorized appliances. But is perfectly ideal for electronics. Electronics are more robust. So robust that even a 'dirtiest' UPS provides power that does not damage any electronics.
This 120 volt sine wave UPS outputs 200 volt square waves with spikes up to 270 volts. It is sufficient and safe for any electronics.
A typical UPS connects AC mains directly to an appliance when not in battery backup mode. It does not clean or regulate voltages. But a manufacturer makes subjective claims in advertising to imply such cleaning. They can lie all they want in subjective brochures. But not lie in specification numbers.
If a UPS does clean or regulate those voltages, then specification numbers defines it (ie %THD). 'Cleaning' numbers are forgotten for one reason. 'Cleaning' exists subjectively. That myth increases sales.
Same applies to surge protection. A hundreds joules surge is converted by electronics into rock stable, low voltage DC to safely power its semiconductors. How many joules does that UPS really claim to absorb or block? Near zero. So few that the surge is made irrelevant by what is already inside electronics. But just enough so that the numerically naive will call it 100% protection.
Tie a knot in a wire. Even that 'cleans' (filters) AC electricity. Then add numbers. It is near zero cleaning. Numbers expose a fallacy.
02-11-2016, 11:10 AM
Ontario
