Old 01-29-2012, 04:19 PM   #1
Generator Automatic Transfer Switch
I own a 2011 Solera and while camping this weekend the the automatic transfer switch did not return to the normal 110v power source after shutting down the generator. I plugged into 110v and had no power in the coach. I cycled the generator on again for a few minuted and when I shut it down the transfer switch operated correctly. My question is does anyone know where the transfer switch and relays are located. I cannot find them. thanks
Kimcrafter is offline   Reply With Quote
Old 01-29-2012, 04:57 PM   #2
sherdep's Avatar
you will get better response if you post in the Solera forum - Solera - Forest River Forums
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-29-2012, 04:58 PM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
Should be right where the cord ties in to your coach. Both cord and generator feed both tie into that same box.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 02-05-2012, 03:18 PM   #4
shooted's Avatar
I can't help you with the location of your ATS, but when you find it I suggest replacing it with a manual transfer switch. ATS is a nice feature but from a reliability perspective manual is the way to go.
shooted is offline   Reply With Quote
