your generator simply 'generates' it's own 120v power, to use just as you use any Shore Power, or household outlet, even.... they are all the 'same' power to your coach.
What's different is:
- how many 'AMPS' you have to use - a typical 50amp RV Shore Power outlet give you two sides, both with 50amps, for a total of 100amps. A 30amp outlet only gives you 30. A household outlet only gives you 15 or 20. Your generator is giving you close to 50amps, between two sides to your Main panel, for a total of 50 only.
- most RV Generators, whether the onboard type, or one's you set outside, are only 120v power output, which is what you and I typically use anyway. But, some are 240v models, for larger motorhomes which have 240v appliances like a DRYER. This is really just like the typical 50amp RV Shore Power you and I normally plug into with our 50amp Shore Cord, but our Main panel inside our coach doesn't make use of the 240v, only two 120v sides.
long story, but true.
