Old 07-28-2016, 06:37 PM   #11
Flybob's Avatar
Just to be safe you can give the attachment to the electrician.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-28-2016, 06:56 PM   #12
SeaDog's Avatar
I run 2 yamaha 2000s for the versatility of being able to use one run to charge batteries and keep lights on and two when there is a heavy load like AC. running only one is very quite and uses very little fuel.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-29-2016, 01:36 PM   #13
Champion 3100 with remote
We have the Champ and for $890 ;ess than half what we paid for our Honda 3000 is it is just about as good and less weight. It runs are A/C perfectly. Also I never had any trouble running A/c at home on a 20 Amp adapter with several different RVs. Just nothing else. Happy camping!!
Mort
mort is offline   Reply With Quote
Old 07-29-2016, 03:47 PM   #14
Hector517, I your second post (#3) you questioned about connecting to 220. I don't think you should ever hook-up to 220. I may be wrong, if so, sorry bout that!
HAppy RVing!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 07-29-2016, 03:57 PM   #15
Usually Confused Member
emm-dee's Avatar
Originally Posted by Hector517 View Post
Bikendan, I am looking at the Champion 75531i 3100 Watt RV Ready Portable Inverter Generator that operates at 58dBA. Regarding my doggone question, I will hire an electrician to install a 30 amp receptacle at my home. Better safe than sorry, right?
Think about future upgrades (you will) and for just a little more bucks put in a 50/30/20 amp box. Same thing you see in the campgrounds and the electrician labor charge should be the same. They just have to run a slightly heavier gauge wire.
Shop Eaton 50-Amp, 30-Amp, 20-Amp Overhead or Underground Temporary Power Panel at Lowes.com
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-29-2016, 05:14 PM   #16
RadRik's Avatar
Based upon my own research and the comments in this forum, I am leaning toward a Champion RV Generator to power my MicroLite 13,500 AC and appliances while on the beach or boondocking somewhere else. I can understand buying a generator with insufficient wattage/ power. Is there a corresponding upper wattage limit? Can a generator with too much power cause an electrical fire or other damages?
I recently purchased the same Champion generator and had no problem running my 13,500 AC unit on a recent week long event. We also borrowed a friend's Honda EU3000i generator to run a food trailer at the same event. I tried both generators to run the camper on different days and found no difference in output on my camper ammeter with the AC running. The Honda was slightly quieter in IMHO, but neither one was too loud to have a normal conversation standing right next to them. The Champion ran the food trailer well also which had a 13,500 AC, a full size fridge and and small freezer. The only issue was when we tried to start the AC, fridge and freezer on the food trailer all at the same time causing to much draw which kicked the breaker on the Champion. Afterwards we started them one at a time and had no problem running all three on the Champion. I think you will be happy with your purchase.
Radi-cool Rik
RadRik is offline   Reply With Quote
Old 07-29-2016, 08:10 PM   #17
Threegaleh's Avatar
Only air
We just got back from camping with only a generator. It's not easy we have a 3100 power house generator almost new. All we could run on it was the air and lights. If you try to use anything else...toaster, coffee pot it quits. We had to remember to turn off the air first. Is there a generator which will run more than the air?
Threegaleh is offline   Reply With Quote
Old 07-29-2016, 08:15 PM   #18
SeaDog's Avatar
See post #12
Retired Navy
2006 F350 6.0
AF&AM of Idaho
Old 07-29-2016, 10:00 PM   #19
I purchased a 3500/4000 max gem from cabelas it's NOT inverter type.
To be safe I FIRST pluged in my progressive surge proctor then camper into proctor..
Wouldn't work so I did some research bought a "generator plug" now it works fine & can run AC.
Louisiana Irishman is offline   Reply With Quote
Old 07-29-2016, 10:13 PM   #20
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
I have had three Champion 3000/3500 gens for several years and never had any problems with any of them. They all crank on the first pull even if it's been several months since the last use. I paid under $300 for each of them from Tractor Supply. They also have a 4000/4600 unit for around $400. I don't buy the inverter units as sound has never been a problem.
All have the 30 amp RV type plug, so no adaptor is needed. Also has a 220 volt/20 amp plug and two 15 amp plugs.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
generator
