Old 12-23-2013, 06:25 PM   #1
Average Joe
MrJoe's Avatar
Generator Help?
We are boondocking in our 2014 Sunseeker. We were running too much on the generator when all 120v shut off. Generator still runs, house breakers ok. Where is the generator breaker?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 12-23-2013, 06:30 PM   #2
dcheatwood's Avatar
If you tell your make and model someone here may have the same and can tell you. Mine has a breaker on the front panel next to the meter and 120vt outlet.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 12-23-2013, 06:32 PM   #3
Average Joe
MrJoe's Avatar
It's a Onan 4000.
Joe and Karen
Old 12-23-2013, 06:33 PM   #4
jonrjen's Avatar
Usually there will be a breaker on the front or top of the generator that needs to be reset. Also check to make sure that your GIF out lets don't need to be reset.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 12-23-2013, 06:36 PM   #5
jonrjen's Avatar
As a side note, many times your house breaker will trip and in order to reset it to the on position you will need to pull the breaker all the way back to the disconnect position before moving it back to the set position. There is a neutral zone that kind of hovers in the middle if you don't do a full reset.
2013 Wildcat 353LS
Old 12-23-2013, 06:36 PM   #6
Average Joe
MrJoe's Avatar
Do you know where the generator breaker is? We looked, but it is hiding itself in the dark.
Joe and Karen
Old 12-23-2013, 06:38 PM   #7
Average Joe
MrJoe's Avatar
FYI. All house breakers and GFCI we checked and exercised. (-:
Joe and Karen
Old 12-23-2013, 06:53 PM   #8
jonrjen's Avatar
I'm looking on the net to see if I can find anything. So far it seems to be hidden pretty well.
2013 Wildcat 353LS
Old 12-23-2013, 06:55 PM   #9
jonrjen's Avatar
I'm trying, here is a link that may be of some assistance.
https://www.equinerv.com/node/2080
2013 Wildcat 353LS
Old 12-23-2013, 07:02 PM   #10
Average Joe
MrJoe's Avatar
Found it! DW found it to the lower right of the manual start switch. Next to the "breaker reset" label. Lol
Thanks for all your help!
Joe and Karen
generator
