Old 01-26-2013, 03:24 PM   #1
FloridaPhil's Avatar
Generator info
I was thinking about getting a generator for my new Rockwood 2306. Any suggestions on what size generator I should get, manufacturer, and where to keep it while running it?
FloridaPhil is offline   Reply With Quote
Old 01-26-2013, 03:30 PM   #2
TURBS's Avatar
A lot of variables here.
Can you run a loud genny where u camp?
Do you want to run your a/c and other things?
Can you lift a big genny into your tv?
More info needed
Turbs
Old 01-26-2013, 03:39 PM   #3
I am willing to spend what is necessary to get model that is not as loud. I am able to pick up and move the generator when necessary and I would like to run the a/c and electronics.
Old 01-26-2013, 03:56 PM   #4
acadianbob's Avatar
You can find a gazillion threads on this subject on a search. I applaud you for your willingness to "go quiet". IMO, your best bet is two Honda EU2000i's; one of which should be a "companion" model. They are easy to heft; one at a time compared to bigger units that will be over 100 pounds. You can use just one if it meets your needs. You can link the two of them together for 4,000 watts if need be. That will run your AC should it come to that. Yamaha also makes some nice units but I don't know if they can be linked. The Honda companion is set up for linking. You may also find it cheaper to get two 2000's vs one 3000.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-26-2013, 04:01 PM   #5
TURBS's Avatar
A 2000 watt will be enough to barely run the a/c "and may not"
Two honda 2000's paired will do great but very pricey.
As a rule a 4000 watt and up genny is going to be loud and heavy.
I run a 5500 watt 6879 surge genny
But its both loud and heavy and we camp on private land and noise is not an issue.
It runs everything I could run on shore power.
Turbs
Old 01-26-2013, 04:06 PM   #6
I would get the yamaha or Honda 2000 and parallel them. It's the easiest on your back and they will do everything you want. I would just look for the best deal on a pair.
chiro is offline   Reply With Quote
Old 01-26-2013, 05:28 PM   #7
tzh99h's Avatar
When you're shopping , just remember you're looking for an Inverter as apposed to a generator, if you are looking for the quieter models
tzh99h is offline   Reply With Quote
Old 01-26-2013, 07:35 PM   #8
bikendan's Avatar
actually, he should look for an inverter generator. an inverter and a generator are two separate things.
the Gold standards are the Honda and Yamaha inverter generators.
IMHO, if you have the money, two 2000w H or Y units paralled, is the best way to go. you can go with the same thing but with cheaper ones made in China, such as Champion's 2000w inverter generators.
they weigh about 50lbs. each and if you don't need the a/c on the trip, then you only need to take one, since it'll run everything else.
otherwise you're talking about a generator between 100 and 130lbs.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-26-2013, 07:57 PM   #9
I run 2- Honda 2000s in parallel with a home made extended run fuel system for extra run time. I have a Crusader 320 RLT with 50 amp service. Really happy with the results.
One benefit with the small 2000s is weight - about 50lbs.- . I can use 1 genny around my house and property for various odd jobs when needed. Ease of handling a big plus.
grayfox is offline   Reply With Quote
Old 01-26-2013, 08:01 PM   #10
Herk7769's Avatar
I have the Yamaha 30SeB which I love. Truth be known if I had to do it over again I would get the 2 Honda EU2000i (with companion). 90% of the time I could have gotten away with running one. The fuel savings alone would have made the second generator free in two seasons.
HAM CALLSIGN - KC3FFW
