Old 04-18-2016, 03:59 PM   #1
Generator output
Hi all,
Where's the best place to take a measure of the AC output from the 8KW Onan generator in my 2009 Berkshire? Easy to get to and not likely to kill me...
Thanks.
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
Old 04-18-2016, 04:09 PM   #2
Originally Posted by jbramhall View Post
Hi all,
Thanks.
Voltage or current. Voltage is easy, any 120 volt plug in the RV, unless you have a problem and are trying to diagnose it. Current not so easy. A clip on ammeter and then turn on your loads (AC, microwave, etc.)
Probably need to know more of why you are asking.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-18-2016, 04:46 PM   #3
I suspect the voltage is low going into my inverter.
Moose
Old 04-18-2016, 05:42 PM   #4
Here's the full description:
House batteries were very low. 12 volt lights would work, but I needed to jump the generator with the chassis batteries to get it to start.
The remote generator monitor in the monitoring center had the "bulk" light blinking. The owners manual for the magnum inverter/charger explained that this could be due to overheated batteries or a low AC voltage input to the inverter/charger. I opened the battery bay and checked that the batteries were not hot. I left the bay open to ambient 70 degrees to be sure.
I checked the voltage to the batteries across the battery terminals, and it was only 12.7V.
The generator was able to run both air conditioners and the refrigerator at the same time, but the voltage to the batteries did not increase to the low 14V I'm accustomed to seeing during bulk charge.
I want to see what AC voltage the generator is supplying to the inverter/charger before I surmise that my inverter/charger is bad.
Any suggestions?
Moose
generator
