05-30-2017, 11:25 PM
New RV Owner
Generator Question
Getting ready to head out on our first trip in a couple of weeks. I had my trailer plugged into shore power last week, but I didn't want to turn on the A/C because it's not a 30amp circuit.
I was thinking about hooking up my house generator to run the the A/C, for the purpose of making sure it's working to elevate any surprises.
Anything I should worry about with doing this?
Rob & Julie
2018 Coachmen Catalina 323BHDS
2016 Nissan NV Pass 3500HD
05-31-2017, 07:22 AM
No reason it shouldn't work at home if it should work at camp!
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
05-31-2017, 07:32 AM
Insert witty title here
Testing at home is always a good idea. I'd rather discover a problem at home than at a campsite somewhere.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
05-31-2017, 09:03 AM
New RV Owner
Not sure if I'm reading your comment wrong, we just bought it new, I haven't been out camping yet... Don't want a surprise when I turn on the A/C...
Rob & Julie
05-31-2017, 09:40 AM
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
For grins, took a look at the current draw for some of the Dometic A/C's which are typical ... other makes are likely similar, you could check the correct spec sheet for yours:
Dometic 540315 - 12.4 Amps
Dometic 540316 - 13.3 Amps
Dometic 541915 - 12.4 Amps
Dometic 541916 - 13.3 Amps
Point is ... even if you are using 15/20 amp house circuit and a "typcial" extension cord and outlet - you should be able to provide a satisfactory 15 amps to test the air conditioner operation. Just don't try to run other appliances at the same time.
NOT saying run the A/C for hours, but a 5 - 15 minute test would be no probbie.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
05-31-2017, 10:49 AM
New RV Owner
I was wondering that, I have an outlet that runs my pool filter, there is no draw on it right now, I was thinking about running it to that.
Rob & Julie
05-31-2017, 11:27 AM
Probably makes sense to turn off the 'converter' breaker so your battery charger isn't drawing...
05-31-2017, 11:57 AM
PROVIDED it is 110 volts that should be fine. If your pool filter is 220 volts, that would be very bad.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-31-2017, 12:38 PM
New RV Owner
Sorry, I didn't word it correctly, it's not the pool filter outlet it's self, that has a specific plug and outlet. I have an outlet attached to that line that is on the outside of my shed... that is on the same line and it is a 110 line.
Rob & Julie
