Old 12-22-2013, 02:19 PM   #1
Generator question
I have a 2014 Sunseeker 3010DS. After removing the 2 deep cell batteries for winter storage, I started the vehicle engine and then the generator. After running for several minutes, I shut off the engine so I could remove the vehicle battery. As soon as the vehicle battery was disconnected, the generator stopped. There is plenty of gas. Does the generator need a battery connected to keep running, or is this a problem?
virgsr is offline   Reply With Quote
Old 12-22-2013, 03:56 PM   #2
Yes needs battery, some built in generators do not have a battery charger and need the 12 volt battery to operate the circuit boards in the generator. That is the way ours is.
drc343 is offline   Reply With Quote
Old 12-22-2013, 04:49 PM   #3
VinceU's Avatar
Its fuel pump operates from avail power supply, otherwise it will stop.
Old 12-22-2013, 05:29 PM   #4
jonrjen's Avatar
Love and marriage. Generator and battery, you can't have one without the other.
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
jonrjen is offline   Reply With Quote
Old 12-22-2013, 05:43 PM   #5
Thumbs up
Thanks for the replies-at least that is one less thing to worry about
generator
