Originally Posted by Mbear12
It’s a 2019 2850 LE with 2000 miles. There is a boost switch on the drivers seat...didn’t know it was there. The generator started from the battery...the charger was still on.
Do you mean, the "boost" switch did the trick or do you think it started because you had a battery charger attached to the battery?
Inquiring minds need to know.
2014 Prime Time Sanibel 3250
