The big question isn’t really what you want to run...I’d start with do you have a 30 amp or 50 amp plug? Math wise, the power you need is current x voltage. Voltage is 120 V, so you need a minimum of 3,600 W generator if you have a 30 amp connection and a minimum of 6,000 W if you have a 50 amp connection. That being said, I’d give some buffer on those numbers since the AC will cause a power spike and you don’t want it to trip off when the AC cuts on. After knowing that, you will want to consider how loud it is, which will be rated in decibels (dB). The lower the number, the quieter and more expensive. 50-60 dB is around normal speech level. 100 dB is LOUD. Then, you move on to convenience features like remote start and such...hope that helps with a base level of knowledge! Brands are brands...that’s personal preference...
