Old 02-17-2016, 10:24 PM   #11
I posted the links to the power house and the Honda 2001 above both have the same watts, the Honda weighs less than 46 lbs the powerhouse weighs 86 lbs. think I'll spend the extra 300 and get the lighter Honda
Stetay is offline   Reply With Quote
Old 02-17-2016, 10:59 PM   #12
bikendan's Avatar
It normally comes down to this:
1. Do you want to run the a/c?
2. Do you want quiet or cheap? Can't have both.
3. Will you be in a campground with others or out in the boonies where there isn't anyone to bother with a noisy generator?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-18-2016, 01:49 AM   #13
HONDAMAN174's Avatar
Generator Recommendations
Check your local craigslist. Mine always has two or three Honda 2000's about 300 less than retail.
Hell, two people are selling companions in my area for 850- 400$ off
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 02-18-2016, 04:53 PM   #14
rracer5's Avatar
OK gang.....rather than re-opening older past post regarding this topic and aside from recommendations/suggestions on the OP's post, I'm interested in specific input/comparison between the Honda EU3000iS and the Powerhouse PH3100Ri. Besides the price difference and the fact that the PH3100Ri has a remote start, I'm looking for reliability comparison, side by side noise comparison, cleanliness of power output etc.
Not that I'm asking for much.
Anybody compared these or been able to compare yours to a friends other brand.........Thanks
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-18-2016, 05:29 PM   #15
Flybob's Avatar
Powerhouse Noise Level . (Zero Load / Full Load) 56 / 65 dB
Honda Noise Level (1/4 load/rated load) 49 dB/ 58 dB
That is a big difference especially in a public campground.
Also search the websites for service and warranty centers near you.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-18-2016, 05:35 PM   #16
rracer5's Avatar
Saw those specs too Bob. Just wondering if anyone had actual "real world" side by side experience.
2014 Sanibel 3250
Old 02-18-2016, 05:50 PM   #17
WaltCole's Avatar
I may just do that, plenty of room in the bed.... the 5500 has a enough to power everything in the TT. I'll just work on muffling it down a bit!
2014 Ram 2500 4x4 Tradesman
2015 Forest River Heritage Glen 302FK
WaltCole is offline   Reply With Quote
Old 02-18-2016, 09:30 PM   #18
bikendan's Avatar
Most generators like that,will still be noisy because it's coming from the motor, not the muffler.
Old 02-18-2016, 10:00 PM   #19
That was what I was going to say
Here is another up and comer that rv'ers are liking:
Champion Power Equipment 75537i Inverter Generator with Wireless Remote, 3100 Watt https://www.amazon.com/dp/B00JZQUSAC..._RlPXwb61FFCYB
Old 02-18-2016, 10:20 PM   #20
The Yamaha EF2000isV2 has a higher EPA rating than either the Honda or the Champion.
Basically, engine life rating. Getting two and running them in parallel makes them easier to transport and handle. One will run most everything with headroom. Two will run the AC\heat, as well. I just went through this exercise a while back. My review is in the appropriate section of this forum, if you want more details. The Yamaha also allows you to shut off the fuel so you can run the engine dry. This is important with most fuels containing some ethanol. Not good for your carb if it sits with this fuel in the carb. Also has a fuel gauge. Not critical, but nice to have.
Inverter generators will give you the cleanest power for TVs, AV equipment, computers, etc. And, if you want to be a good neighbor, the added cost will earn you bonus points in the campground.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
generator
