Old 09-01-2015, 10:36 PM   #11
I had a single Honda eu2000i that I sold for $800 and purchased a Champion 3100 watt inverter generator (no-electric start) and it runs my 13.5k btu AC no problem. If you are wanting to run the microwave and the AC at the same time, find some place to plug in the trailer, that's too much load for a generator (your microwave/hairdryer/waffle iron etc could draw 1500 watts by itself).
The Champion weighs 75 pounds I think, and has two big handles that make it easy to heft into the truck. It also has a handle and wheels for pulling it around (a paved) campsite with ease. Its clean SINE wave power, has auto throttle, and it will run the AC with the auto throttle on! Now my father in law purchased the same generator for his trailer but his will not run the AC unless he shuts off the breaker for his inverter/charger, but that could be because his batteries are bad and require a big influx of power when the inverter/charger is active. And you can buy the champion on Amazon for $840 delivered to your door.
coolzzy is offline   Reply With Quote
Old 09-01-2015, 10:47 PM   #12
Left Coast
A hard start capacitor could help with his problem
Old 09-01-2015, 10:48 PM   #13
trbomax's Avatar
I have a rack mounted 3500 honda that will supply 220 or 110.It will fit in my gen compartment too! I'm pretty sure where its gonnend up!
trbomax is offline   Reply With Quote
Old 09-01-2015, 11:12 PM   #14
GmanHawaii's Avatar
Check out Kipor quiet like a Honda and half the price.
GmanHawaii is offline   Reply With Quote
Old 09-01-2015, 11:21 PM   #15
northstar1960's Avatar
Originally Posted by captnemo View Post
I have a Forest River Grey Wolf 26 BH and I am wondering what size generator (Operating Load / Surge Load) to purchase to operate my camper. It has one 13,500 Air conditioner and I would like to be able to run the AC and not have to worry about overloading the unit if I turn the TV or other appliance on at the same time? I emailed Forest River but could not get a response?
I picked up the champion 3500w with remote start , have put about 100 hrs on it with out issue . it's a bit heavier but not hard to move around , quite for it's size and only $399.00 . the remote start is a great feature . not having to go out to start it up for coffee in the AM a big plus
northstar1960 is offline   Reply With Quote
Old 09-02-2015, 03:59 AM   #16
bikendan's Avatar
Great generator for boondocking, motor races and festivals.
but not for campgrounds, due to its noise level. it's still a open frame contractor-style non-inverter generator, which means LOUD for your neighbors in the next campsite.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-02-2015, 04:14 AM   #17
Start with HONDA and work Down if Cost is a issue. Youroo!!
Old 09-02-2015, 10:01 AM   #18
No not bad at all . not much worse then the others . if in a campground where no electric and gen use is allowed for certain time periods then it's fine .
Old 09-02-2015, 11:50 AM   #19
A good choice is the Champion 2000, as quiet and reliable as a Honda and 1/2 the price. Two connected in parallel will run your AC and you can run just one for battery charging, microwave etc when not using the AC.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 09-02-2015, 12:14 PM   #20
Scubanut's Avatar
I have a 2700w generator and have a hard start capacitor in my 13,500. It sometimes will run if nothing else is on but will blow the fuse at some point within an hour. I would think 3100w at the bare min.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
generator
