Old 02-07-2015, 07:39 AM   #1
gmann55's Avatar
Generator shut down
2008 Georgetown 370 with an Oman 5500 watt generator. It will run all night no problem. It will run for about a half an hour going down the road and then shuts off. If I stop and turn the engine off it will state right up and run good until I start the coach and we go down the road again or just idle in the parking lot. It will then shut off! Any ideas out there?
gmann55 is offline   Reply With Quote
Old 02-11-2015, 10:07 AM   #2
Double check your oil level, may be a little low.
Is there and error code displayed when it shuts down?
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 02-11-2015, 10:10 AM   #3
TURBS's Avatar
My guess is low oil to.
Old 02-11-2015, 01:05 PM   #4
gmann55's Avatar
Just checked the oil and it was right between add and full. I did add a little oil to bring it up to bring it up to full? Not sure about how to read the code but by the time I stop and get back to the gen will the code still flash? I am parked until April!
Old 02-11-2015, 01:28 PM   #5
Campin Cajun's Avatar
Sounds like a fuel delivery problem to me. That genset has had carburetor problems.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 02-12-2015, 07:02 AM   #6
gmann55's Avatar
Campin Cajun . Are you suggesting a bad fuel filter possibly?
Old 02-12-2015, 07:05 AM   #7
TURBS's Avatar
Didn't someone have a pinched fuel line awhile back?
Old 02-12-2015, 07:18 AM   #8
rattleNsmoke's Avatar
If the car has a float that is set too low, fuel starvation will occur when cornering....just like classic car problems.
rattleNsmoke is offline   Reply With Quote
Old 02-12-2015, 07:45 AM   #9
gmann it could be a filter problem.
The way I try to solve problems is changing out the least expensive parts first. You checked the oil level, that was good and didn't solve. Try changing the filter and looking for a pinched line, if that doesn't help it may be the carb.
Old 04-19-2015, 07:30 PM   #10
jjd74's Avatar
You consider the genny is overheating? Where is it located relative to the engine?
jjd74 is offline   Reply With Quote
generator
