Old 08-06-2012, 12:49 PM   #1
generator wires
I tore the wires out of the generator plug while removing the generator. I need to get info on the wiring diagram. The pins came out of the plug intact to the wires. I just need to know which way they go back in. The wires on the generator are all white. The wires on the motorhome are colored.
thanks
Blgrow
blgrow is offline   Reply With Quote
Old 08-06-2012, 02:23 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Onan - Generator Accessory Catalog.pdf
It would be helpful to include the Model of the Generator you need info about as well as the model of your RV.
I'm guessing you're talking about the harness similar to the type starting on page 60 in the above pdf. You may need to contact Onan Technical support for the info you need. Let us know what you find out.
to the Forums!
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
