Old 06-13-2012, 10:51 AM   #1
TURBS's Avatar
generator with floating neutral
I need some one very versed in a L14-30 30 AMP generator outlet with floating neutral.
Old 06-13-2012, 12:12 PM   #2
Sounds like you are trying to run an unbalanced load. Try putting a small ground rod by the generator (a 3' X 5/8" rod should be enough) and run a #8 wire to the generator frame from the ground rod. If that doesn't fix it, you may want to hire a qualified electrician to open the generator panel to make sure that the neutral is bonded to the ground.
Birddog is offline   Reply With Quote
Old 06-13-2012, 12:19 PM   #3
TURBS's Avatar
With the floating neutral the L14-30 receptical 120/240 only puts out half of rated load on 120. I can't get enough amps.
Stupid design.
