Generator won't Power A/C
Specifics:
Class C 2012 Lexington
A/C - Dometic Penguin II with Heat Pump
Generator - Onan RV QG 4000
When trying to start the A/C while under generator power, the generator bogs down and shuts off. The flashing light error code indicates too much load such as trying to run A/C while battery charger is running. I turned the house battery disconnect switch to off and tried again. Fan came on but the compressor won't kick over.
It seems unusual that the installed generator can't pull the load, but it can do everything else but the A/C. Is this normal?
Would a Micro-Air Easy Start be a possible solution?
2012 Lexington C Class
Toad: 2009 Honda Fit
