Old 07-01-2013, 09:23 PM   #1
Question Genesis Media payer trips GFI
In my 2012 Flagstaff 23lb I can't turn on the breaker for the multimedia system if plugged into a gfi pedestal. It trips the gfi instantly. If I leave the breaker off it will run off the 12 volt no problem. Also non gfi plugs work as well.
Any ideas where I should start?
Jetter
Jetter is offline   Reply With Quote
Old 07-01-2013, 09:54 PM   #2
Dabmeb's Avatar
Jetter
My understanding is you cannot have two gfi plugs on the same circuit, one will trip the other. You may have to get that circuit changed to a non gfi plug.
Dabmeb is offline   Reply With Quote
Old 07-02-2013, 09:08 AM   #3
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
I am confused as the Genesis Radio is 12V DC and should be connected to a fuse at the converter.
What breaker are you talking about?
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 07-02-2013, 10:05 AM   #4
The bottom one on my panel. It's labelled "radio". Maybe it's not the radio?
Old 07-02-2013, 11:00 AM   #5
Sorry my mistake. I misread the fuse panel. It is water heater that is tripping GFI pedestal!
Old 07-02-2013, 11:15 AM   #6
Fulltime family RVer
This is essentially your problem. My mother-in-law watches those HGTV "flip this house" types of shows. I happened to remember one episode where they were having issues with a hot tub that wouldn't work. Turns out - it was a GFCI outlet that was wired into another GFCI outlet and they'd trip each other. That little nugget stuck with me, but never meant anything.
Fast forward to reading threads here - and I've read the same thing.
It doesn't necessarily *always* trip the GFCI, it can be inconsistent.
Your only option for it to consistently work is to not plug into a GFCI outlet.
ependydad is online now   Reply With Quote
