Old 12-16-2017, 05:12 PM   #1
gmann55's Avatar
Genrac generator
I have a 2007 6500 watt genrac generator in a 334se Georgetown motorhome! The generator will not start! I push the start bottom and nothing! I can push the primer and the pump works but engine will not crank! I have 2 new batteries in the motorhome! It will not start from the drivers seat or right at the generator? Any ideas! I do have 12 volts at the generator? Help!
gmann55 is online now   Reply With Quote
Old 12-20-2017, 07:57 AM   #2
SeaDog's Avatar
Make sure any fuse/circuit breaker on the generator is reset or good. Check and see if you actually are getting voltage to the starting motor when you hit the start button. It may be that the starter motor has gone south. I don't have a Genrac so this is a best guess on my part.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 12-20-2017, 08:02 AM   #3
gmann55's Avatar
I am not getting voltage to the starter!
Old 12-20-2017, 08:03 AM   #4
Pickin' & Campin'
Not sure if this is a new to you unit or if this is something that just happened.
Some generators have a 'push and hold wait to start' when pushing the button to allow for priming and choke.
Days Camped: '15=22 '16=46 '17=30 '18=21
Old 12-20-2017, 09:25 AM   #5
gmann55's Avatar
This just happened! It has always worked before!
Old 12-20-2017, 09:33 AM   #6
Pickin' & Campin'
Well then you are going to need to do some circuit checking.
If there is no voltage at the starter, how about at the switch?
Old 12-20-2017, 09:42 AM   #7
Try starting the motorhome and see if the genny will crank then. Are you disconnected from shore power?
Paul S. is offline   Reply With Quote
Old 12-22-2017, 12:48 AM   #8
Netgain's Avatar
Old school .... if you can reach the starter, try tapping on it with something like a screwdriver handle while you press the start switch. I've gotten starters, fuel pumps and alternators to work doing this as a temporary fix.
Netgain is online now   Reply With Quote
Old 12-22-2017, 08:56 AM   #9
gmann55's Avatar
I can even see the starter! I dont know if I need to take generator out of motorhome to work on it? Anybody had any experience with this?
Old 12-22-2017, 09:02 AM   #10
Thurman's Avatar
As previously stated you are going to need to do some circuit checking. Starting at the starter and checking everything in the starting circuit all the way back to the battery. If you can't see the starter then how did you check the voltage to the starter?
Thurman is offline   Reply With Quote
generator
