Old 06-10-2016, 07:45 PM   #11
I seem to be having a problem that is similar to this post. Every other week over the winter I ran the RV at 4000 for an hour and everything was ok. I line in NY so it was below freezing. Now the generator runs for 10 to 20 minutes stutters and shuts down. The last code I saw was 3 then 6. There is fuel in the tank. Any ideas I am 2 weeks away from a cross country trip.
bdifonzo is offline   Reply With Quote
Old 06-10-2016, 08:00 PM   #12
Agree, first place to look is the fuel pump. Airteck makes a replacement better than the OEM. You can find your manuals here Index of /~n0nas/manuals/onan
BBQGUY is offline   Reply With Quote
Old 06-10-2016, 08:11 PM   #13
Fuel goes bad. Did you add a fuel stabilizer before you stored the unit for the winter? Assume you have done the yearly service (change oil, oil filter, fuel filter, air filter, new plugs). Most common problems are related to ethanol fuel, carburetors, and fuel pumps. Carburetors can not be rebuilt; replaced only.
Old 06-10-2016, 09:37 PM   #14
First check for trash in the carb bowl. Pinch off incoming fuel line first.
You can also rebuild the carb. Get the right kit, take apart and soak in amonia for an hour. Blow out all the passages and put back together.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 06-12-2016, 07:32 PM   #15
Thanks everybody on Friday I ordered fuel pump, air filter, and fuel filter from Amazon. Arrived today. I installed and then ran the generator for two hours. Worked like it's supposed to.
Old 06-27-2016, 07:34 AM   #16
More help needed. On a major road trip. My generator works when not moving for hours. When I start to drive it runs about 20 minutes. Any ideas?
Old 07-25-2016, 10:35 PM   #17
gmann55's Avatar
Changed fuel pump on my 5500 watt gen and that solved the problem!
gmann55 is offline   Reply With Quote
