Old 07-03-2015, 12:20 PM   #1
GFCI issues
I have a Sandpiper 35Loft (Treehouse) 5th wheel and I am trying to resolve a problem with outlets not working. All the outlets have the protected by GFCI but the only one I can find is the one in the main bathroom. It does not reset and seems to not have power.
Does anyone know where a breaker or another GFCI might be located upstream from this?
Dblomgren is offline   Reply With Quote
Old 07-03-2015, 12:49 PM   #2
There should be another CFCI outlet with the "Test" and "Reset" buttons in the kitchen.
When you press "Test" on the GFCI in the bath, can you hear it trip?? Once it trips, you should be able to reset it.
You are plugged in to 110 somehow correct?? Campground post or house or generator ----
I don't have your model so I can't tell you exactly where your breakers and fuses are, but they will both be in the same panel probably with a louvered front with a single screw to remove for removal of the front panel. Probably floor level close to or in the kitchen.
bruceatlam is offline   Reply With Quote
Old 07-03-2015, 01:14 PM   #3
Thanks for the reply.
Problem solved. There was a panel below the control panel that I thought was and inverter when in fact it was a circuit panel. I found the tripped breaker and reset it and all is well. I do still need to track down the problem that tripped it to begin with.
