Old 12-23-2014, 10:12 AM   #1
Red face GFCI will not reset
Looking for some advice. I have a brand new rockwood signature 8293 IKRBS and of course while taking it cross country I run into an electrical issue. I was at one of the over night stops on my journey and I hear a pop in the cabinet behind the electrical box. Next thing I know, half of my outlets have stopped working and one of the two GFCI outlets in the trailer will not reset. Obviously, all nonworking outlets are branched off that GFCI that won't reset, resulting in losing half the power outlets in the trailer. So trouble shooting begins!
I check the breaker and it has not flipped. I flip it off anyways, wait 30 seconds and flip it on. The GFCI in the bathroom continues to work, the one in the island still will not reset. So I open up the outlet, and unlplug the two wires leading off the GFCI in hope the issue lies in one of the branches and hoping I can reset the GFCI with just the main power going into it. No luck. So, I purchase a new GFCI outlet and change out the one in the island. Still won't reset. So my next assumption is that the issue lies between the GFCI and the breaker box. I know there is a panel that opens up behind the breaker box in the trailer that has a few more electrical boxes for the landing gear and other electrical devices. My hope is their a fuse somewhere in there I can replace and get this power back to normal since that is where I originally heard the noise prior to losing the outlet.
And yes, I already called the warranty department and we had an exhausting talk about me bring my trailer into service after the holiday since I am currently living in it far from home for two weeks. Any help with an electrical diagram or advice on what the issue is, would be appreciated. Happy Holidays all and thank you for your time.
colman140 is offline   Reply With Quote
Old 12-23-2014, 10:54 AM   #2
Were you deploying any of the (3) slides when this started? The (Kitchen) slide might have (Pinched/broken) the feeder wires! Just a wild guess! Youroo!!
youroo is online now   Reply With Quote
Old 12-23-2014, 11:13 AM   #3
mcnabbwr's Avatar
Have you tested to see if there is power to the line side of the GFI? Possible issue with the breaker or main panel or as stated in previous post broken wire.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 12-23-2014, 11:38 AM   #4
I agree you need to test the LINE side of the GFCI to see if you have power. Even with the breaker appearing to close normally (on) it may not be.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-23-2014, 12:16 PM   #5
Flagstaffer06's Avatar
x2 on what Youroo said, I've seen it happen. They make the wire bundles that go out with the slides just long enough to make things work sometimes. I just helped my neighbor this summer actually add some wiring to the harness because his was so short it kept breaking the connector. We also found some pinched wires too.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 12-23-2014, 12:26 PM   #6
Had the same problem in my Georgetown. One of the wire nuts was not properly installed and came loose. The junction box was behind the circuit breaker box and a pain to get to. However, I managed and reinstalled the wire nut properly.
jamesrnewton is offline   Reply With Quote
Old 12-23-2014, 01:26 PM   #7
Happy Campers
Denny and Suni's Avatar
GFCI Test
Home improvement stores have outlet tester.
You could have an open ground, or your neutral could be reversed with the ground wire. The tester is a cheap way to eliminate these possibilities.
"I went to the woods because I wished to live deliberately...and not, when I came to die, to discover that I had not lived." H. D. Thoreau
2012 Nissan Frontier 4X4 Crew Cab Longbed
2014 Flagstaff 21FBRS
Some Yorkies
Denny and Suni is offline   Reply With Quote
Old 12-23-2014, 01:34 PM   #8
GFCI wont reset
Had the same problem I my Cedar Creek tried everything you did and more, the problem was loose white wire in the breaker panel tightened it up and it solved the problem!!!!!!!!!!!!!!!!
jackssilverback29 is offline   Reply With Quote
Old 12-23-2014, 01:44 PM   #9
Based on the OP's description neither of these are likely. It was working fine at first.
2010 Chevy Suburban
Old 12-23-2014, 04:07 PM   #10
Just for info - my Rockwood 8280 5th has no 110 electric outlets in either slide. All 110 wiring is in the main shell (interior walls only) of the camper. I thought this was weird at first, but may be blessing in disguise. Obviously Forest River saved a lot of construction cost by doing that.
Ken Halloran is offline   Reply With Quote
