Old 01-02-2016, 05:40 AM   #1
gfi not resetting
I have just hauled my Blue Ridge to Florida after owning for 5 yrs and being stationary. On arrival I have 2 gfi's that will not reset and I have no power to 6 outlets. Any ideas out there. I do have power to one gfi and have power to my entertainment and outlet near stove all on same slideout
boo798 is offline   Reply With Quote
Old 01-02-2016, 06:07 AM   #2
If you have power to the gfci and it will not reset it is bad and has to be replaced. If they do not have power to them most if not all will not reset.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 01-02-2016, 07:16 AM   #3
I had the exact same issue and they replaced the bathroom GFI control outlet. Still NG. Turns out, one of the ground wires came loose. Once they found the bad wire, everything OK. You will need a power checker to plug in and check for ground - not just power.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 01-02-2016, 07:58 AM   #4
Check to see if you have a breaker that has tripped. As Toddupton stated, they generally will not reset if they have no power.
Travel safe
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is online now   Reply With Quote
Old 01-02-2016, 07:58 AM   #5
Flybob's Avatar
On cell so don't see rig type but 3 gfis prob 50A service. Good chance one leg at pedestal bad. Assume you are not using 30-50 adapter
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-03-2016, 05:36 AM   #6
Thanks Everyone for your help. I hauled yesterday another 4 hrs and when we set up we had all our power back. Must be a loose ground somewhere.Can't tell now that everything is working.Will be moving again in a month so see if it rears its head again so I can check for bad ground wire.
