GFIC Electric Outlets have no reset button (2005 Flagstaff SD-LTD Pop-Up Camper)
Hello, I have a 2005 Flagstaff SD-LTD Pop-Up Camper. There appears to be only 3 power outlets on the inside (none on the outside). 1 is near the rear bunk. Two are near the front bunk on both sides. There is is GFIC sticker on all 3 receptacles but when I remove the plastic cover plate there is no reset button on any of the 3 receptacles.
None of the 3 receptacles have power currently. The overhead air conditioner and installed lighting both work fine when the camper is plugged-in to the RV park's power post.
I contacted Forest River and was told the following: "the outlet closest to your converter breaker box will have a reset button right on the outlet. Then all the others are controlled through this one, thus they are labeled GFI protected.". However, none of these 3 outlets have the reset button. I'm not sure where to turn next.
Thanks for any advice.
Mark
