Old 06-03-2014, 12:40 AM   #1
CBergstrom's Avatar
GoPower Flex Solar Panel Install and Battery Upgrade
Thought I would share my weekend's work.* I installed a new flexible solar panel to the roof of our Sabre 34TBOK and switched out our 12v battery for two 6v Trojan T105.*
We don't do a lot of boon docking but we find that when we do, on a cool night where the furnace runs a few times, our battery is dead by morning.* Add to that, we don't have shore power at the storage lot so it's rare to get a full charge before we head out. We are also hoping that we will be able to keep the fridge going between trips in the summer and cut down the loading time and fridge space required at home.*
The panel is a GoPower! Flex 100 and is 100 watts and comes with a 30amp pwm charge controller.* As with most panels, this one has the option to tie in additional panels.*
Overall the panel install was pretty straight forward.* I went with the flex as I didn't like the idea of drilling holes in the roof and the curve of our roof was likely to be an issue with a rigid panel without some serious shims. To mount the panel, I used Dicor on the bottom and around the edges. I wired the system directly to the batteries so that the panel can continue to charge the batteries even if I have the battery disconnect switch turned off.* This will hopefully keep the batteries maintained over the winter.*
The battery install was easy but required cutting a hole in the metal subfloor to put in a drop in battery box like the one the trailer comes with from factory.* Sparks and RV building materials make me nervous!
The only real problems I encountered was trying to fish the panel wires under the floor between the kitchen and the steps up to the master bunk.* I ended up having to cut another hole in the floor behind the steps in order to get my hand under there to clear away the insulation and guide the fish tape. The other issue was installing the charge controller as I ran into a wood stud that I wasn't anticipating but a few notches with the scroll saw fixed that up.
Overall, I'm happy with the way it turned out and I seen parts of our rv that one never thinks to look at. * And is there ever saw dust from the factory behind panels! *
In full sun the panel was putting out 19 volts before the controller and was cranking out 4.1 amps according to the display. If we can get a solid 4-5 hours a day at that rate for most of a week, I'll be happy with that.*
Total investment is about $1100 CDN with the panel kit costing $650, batteries at $350, plus battery cables and box with vent.*
Here are some pics of the install:
Name:	ImageUploadedByForest River Forums1401773796.087076.jpg
ID:	54204Click image for larger version
Name:	ImageUploadedByForest River Forums1401773810.000661.jpg
ID:	54205Click image for larger version
Name:	ImageUploadedByForest River Forums1401773828.132336.jpg
ID:	54206Click image for larger version
Name:	ImageUploadedByForest River Forums1401773848.152875.jpg
ID:	54207Click image for larger version
Name:	ImageUploadedByForest River Forums1401773881.099442.jpg
Name:	ImageUploadedByForest River Forums1401773932.357689.jpg
ID:	54210Click image for larger version
Name:	ImageUploadedByForest River Forums1401773977.720928.jpg
CBergstrom is offline   Reply With Quote
Old 06-03-2014, 01:18 AM   #2
Just a member
kandl's Avatar
Very nice! Where did you source the panel? It'll be interesting to see if in fact the setup does keep the batteries up during the winter.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 06-03-2014, 08:11 AM   #3
CBergstrom's Avatar
I got mine at The Lawnmower Hospital in Edmonton as they had the best price. Woody's RV also carries them.
It should keep them maintained over the winter because with the disconnect switch the only draw will be the natural dissipation of charge to which the panel should keep up with that.
Old 12-06-2015, 08:42 AM   #4
Kenny kustom's Avatar
Where did you run though from the roof to the basement?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-06-2015, 11:27 AM   #5
CBergstrom's Avatar
From the fridge I ran the cable through the cupboards and went into the floor where the wiring for the monitor panel goes down. From there I fished the cable through the floor and then up into the basement. I had to cut a hole in the floor just behind the stairs so I could fish the cable up. It was a real PITA to get under the floor and without a fish tape it would be impossible.
Old 12-06-2015, 11:59 AM   #6
A32Deuce's Avatar
Amazon and EBay are also good places to get Go-Power.
A32Deuce is online now   Reply With Quote
Old 12-06-2015, 12:07 PM   #7
John McClain's Avatar
My I ask why ? 2 105 6 volt Batteries ?
Two 6 volt 105 Capacity Amp-Hours at 20 aph = 225 total
Two 12 volt J150 Capacity Amp-Hours at 20 aph = 300 total
If you have one of your 6 volts go bad your dead in the water
If you loose one of the 12 volt you just disconnect it and run at half throttle
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 12-07-2015, 04:17 PM   #8
Unless you are monitoring your batteries very closely (like several times a day), failure of one 12V battery is going to discharge any paralleled 12V batteries before you know to disconnect the first. I learned the hard way you are usually just as dead as with failure of a 6V.
I now have 2 Costco 6V golf cart batteries with 232AH each (total cost $150) that fit into the same box my previous dual size 24 12V did. The size 24 12V batteries were rated at 85AH each, so I gained capacity by switching to 6V.
Fred W
2014 Rockwood A122 a-frame
Old 12-07-2015, 05:00 PM   #9
J150 is 3" longer (may not fit the battery carrier) and weighs 22 lbs more than the T105.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 12-07-2015, 07:05 PM   #10
Did you screw the cable clamps to the roof or just dicor them?
jimcarterhb1951 is offline   Reply With Quote
battery, power, solar, upgrade
