Ground control TT leveling system
Need some help from someone that has this system.
Unit is 3 months old and has been perfect til now.
Usually, I unhitch truck using the ext/ret switch on tongue jack and then go to LCD panel, turn the system on and hit Auto Level.
This morning I heard the tongue jack activate briefly on its own.
Thinking maybe it was bumped and partially engaged my Son hit the ext/ret switch and it stopped. Could have been a fluke as we were all all around the jack 5 seconds earlier.
But strangely now anytime the tongue jack is used it "powers on" the LCD touch panel/system.
Called Lippert and spoke with customer support. They have never seen this either and recommended taking it back to the dealer which I will when we return home in July. The unit operates perfectly otherwise, may be haunted I guess.
I acquired the factory install manual and checked every wire physically and electrically and all is good there, actually a very good and clean install by Forest River.
My question is for those of you who have the Ground Control TT System, does yours power on automatically when the tongue jack is used?
The manual and Lippert states it is not normal, it should only power on when the power button on the LCD panel is pressed.
Curious to how many folks (if any) on this forum may have experienced this phenomena.
