Old 07-23-2014, 09:55 AM   #21
Originally Posted by Kuba View Post
Backup power for home appliances etc. For example if you had a bunch of car batteries and wanted an inverter to run any home appliances of the batteries in case power goes out(110-120v AC). You are good to go and have nothing to worry about.
I get that but the point of my question was particular to this case..
The Op is asking about a particular scenario in his/her RV. They also stated that this is a motor home so the potential for noise on a ground if left floating is very high.
Now I may be understanding something wrong here as well...If by "CPAP" the Op meant "Coffee Pot And Percolator", then by all means forget the ground...It's not worth the trouble..But if the Op was referring to CPAP as in a "Continuos Positive Air Pressure" Breathing Apparatus, then it's worth the trouble to keep any ground noise from damaging this expensive piece of medical equipment.
Bmbrady77 is offline   Reply With Quote
Old 07-23-2014, 10:33 AM   #22
Puzzlme
Puzzlme's Avatar
Ok so for my application I don't need to ground it. Everything is good to go. Thanks
The fellow at go power wasn't clear himself about having to ground the inverter.
https://rhodaventure.com/
2013 Sunseeker 3010DS
2014 - 15,000 Kilometers (9360 Miles) Alberta through the US to E. coast, up into Atlantic Canada, Newfoundland and back.
2015 - 2 great trips so far. Alberta to Oregon coast, Alberta to Shushwap in BC.
Puzzlme is offline   Reply With Quote
Old 07-23-2014, 10:39 AM   #23
Puzzlme
Puzzlme's Avatar
Yes an expensive medical device. So if I break through the insulation on the black wire I can use alligator clips. One on the exposed black and one on the inverter. Then wrap up the black wire with electric tape.
Old 07-23-2014, 10:45 AM   #24
If its an expensive medical device i would strongly recommend you get a xantrex, aims or schneider inverter. I would also recommend a PURE SINE WAVE. With one like that you will get the cleanest power for your medical equipment.
Your inverter is already grounded if its a mobile inverter and connected to cars battery
Kuba is offline   Reply With Quote
Old 07-23-2014, 10:47 AM   #25
Or samlex which is now cotek.
Old 07-23-2014, 10:48 AM   #26
Do you have a volt metee?
Old 07-23-2014, 10:55 AM   #27
Meter
Old 07-23-2014, 12:45 PM   #28
Puzzlme
Puzzlme's Avatar
No volt meter. My inverter is pure sine. By connected to car battery do you mean the house (deep cycle) batteries in the Motorhome? There is a DC outlet in the motorhome, I won't be accessing the dash outlet in the cab.
Old 07-23-2014, 01:16 PM   #29
RPAspey's Avatar
Bottom line, you have a pure sine wave inverter that doesn't need a special ground if used in your rv.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-23-2014, 01:22 PM   #30
Puzzlme
Puzzlme's Avatar
Thank you
inverter
