Old 01-29-2016, 07:51 AM   #11
fmc
fmc's Avatar
It must be off eco-throttle to run the AC. For those of you that find the Dometic generator difficult to start I found that the slot for the choke lever was not long enough. The choke was not allowed to be fully closed. I elongated the slot and the generator starts much easier even in very cold weather.
fmc is offline   Reply With Quote
Old 01-29-2016, 08:49 AM   #12
WolfWhistle's Avatar
Keep in mind, these small generators are not rated for continuous max load. We should consider how well one ( or two) that we want to buy will do on a 105° day and how well it handles a "hot" restart. Ever heard the term "you get what you pay for"?
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 01-29-2016, 08:58 AM   #13
AquaMan's Avatar
X2
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-29-2016, 10:59 AM   #14
Mark S's Avatar
Thanks for all the input guys. It sounds, like I expected, too close for comfort.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 01-29-2016, 04:13 PM   #15
I have used a Honda 3.000 for years.
I turn refrig & w/h to propane, turn converter and all other a/c draws off.
Turn eco mode off
Yes very rearely did the overlimit trip but i like the quiet Honda. After the
a/c is running limit additional a/c draws. A hard start kit will benefit you.
Don't forget to re-enable disabled a/c devices.
The key is power management.
Ohms Law
W=V*A
mfMcFroggierPod is offline   Reply With Quote
Old 01-29-2016, 04:56 PM   #16
AquaMan's Avatar
If you have an EMS, it will kick out before you harm your A/C anyway.
Old 01-29-2016, 09:05 PM   #17
Too Tall's Avatar
Any recommendations on a hard start capacitor for a Coleman Mach III 13.5. I'm going to try to run it with a 2400 surge, 2100 running generator. Think I can do it?
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 01-29-2016, 10:10 PM   #18
HONDAMAN174's Avatar
It might. But it would run at 100% all the time and no power left to charge batteries.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-30-2016, 12:30 AM   #19
Too Tall's Avatar
Yes, I didn't buy it for that purpose but it would be nice. It's purpose is to charge batteries and make coffee. (It can be paired).
Has anyone found that the hard start capacitor provide a benefit for starting load? thanks.
USMC 68 -70
Old 01-30-2016, 07:56 AM   #20
When hooked to shore power, I have noticed a difference.
SUPCO HS6 (SPP6) Hard Start Relay Capacitor https://www.amazon.com/dp/B0002YTLFE..._aamRwbBVGJGB1
Being they are rather cheap, I bought two in case another camper needs the helping hand.
Just don't remove the relay that it comes with and just follow wiring diagram on your ac unit.
generator
