Old 01-26-2016, 11:18 AM   #1
Mark S's Avatar
Hard start capacitor/generator question
Greetings. I have a Dometic 15 K BTU air conditioner and a Dometic 3,000 watt inverter generator. I know the numbers are very close but I was wondering if I were to add a hard start capacitor to my AC if this generator will run the AC.
I use the generator very, very rarely and cannot justify buying a new one. I would really like to make this combo work if possible without hurting the AC or generator.
Any thoughts please.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 01-26-2016, 11:55 AM   #2
WolfWhistle's Avatar
I don't have such a combination, but if I read it right, the generator is able to make 2600W continuously and 2900W peak; that's about 21 amp continuous and 24 amps peak @ 120 vac. If the voltage is lower the current (amps) will be higher.
Converting watts to amps: Watts / Volts = Amps or properly stated P / E = I
The new Briskaire II 15K draws about 11 amps run (some web sites show 16 amps for some 15K units) and about 21 amps to start, which could be lower with the start assist capacitor, such as the Supco SPP6.
By the numbers along and only running the A/C on the genset, it should be able to do it. I would think the 3000W (actually 2600W) Dometic is undersize for daily and / or continuous use.
BTW, Dometic recommends a minimum of 3500W genset for both the 13.5K and the 15K units.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 01-28-2016, 07:07 AM   #3
Mark S's Avatar
Thanks for the reply. If I did use this it would be very rare. But you are right, the numbers are really tight. Thanks
Mark and Joanne
Old 01-28-2016, 07:50 AM   #4
TURBS's Avatar
Dometic recommends 2500 running watts.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-28-2016, 08:24 AM   #5
AquaMan's Avatar
I have the Dometic 3000 watt generator also, and it would run my 13.5k A/C no problem. That was without any mods to A/C. I had good intentions of trying to run my 15K A/C, but never did. Best possible scenario would be to utilize a hard start capacitor and a time delay on the fan in order for it to work. If it's too much draw, the generator will shut down fairly quickly. I have used this generator on my 12" Dewalt Mitre saw, which has a huge start up draw and 15 amp running, and if I don't feather the trigger a bit, it will kill the generator.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-28-2016, 11:12 AM   #6
Dometic B59516 Brisk II RV Air Conditioner 15,000 BTU White
Click Specification... Read down
Old 01-28-2016, 04:43 PM   #7
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I've been in the AC business for 40+ years and you're pushing it and tempting the gods if you do this.Too close for comfort zone to exist.
Grampa Jim is offline   Reply With Quote
Old 01-29-2016, 07:06 AM   #8
It may be okay at sea level but at any altitude the motor will lose power and you won't get enough power from the generator to run the AC.
dontay is offline   Reply With Quote
Old 01-29-2016, 07:37 AM   #9
My champion 3100w (2800w running) runs my Dometic 15k without issue even in economy mode. When running in economy mode, I turn the fan on first then turn on the A/C so it doesn't start them both at the same time. If I'm not running in economy mode I can start the generator then turn on the fan and A/C at the same time. Obviously a different generator, but similar wattage and A/C unit for comparison.
2015 Work and Play 30WRS
2005 Dodge Ram 2500 4x4 diesel
wildbill79 is offline   Reply With Quote
Old 01-29-2016, 07:38 AM   #10
dieselguy's Avatar
I have an 6 year old Kipor similar to the current IG3000 model. It's very near your generator's specs. If I have most everything else off save the converter, it will easily run my 15K A/C if I leave it off ecothrottle. I'm like you elude to ... rarely need to run the big A/C on the generator, but nice when the need arises.
dieselguy is offline   Reply With Quote
generator
